A wire with a resistance R is lengthened to 1.25
  • Thread starter Thread starter discoverer02
    Resistance Wire
The problem involves a wire with an initial resistance R that is stretched to 1.25 times its original length. Participants are discussing how this change in length affects the resistance of the wire, referencing the relationship between resistance, resistivity, length, and cross-sectional area.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between the wire's length and radius, questioning whether the decrease in radius is proportional to the increase in length. They discuss the implications of volume conservation and its effect on resistance calculations.
Some participants have offered insights into the relationship between area and length, leading to a reevaluation of the original calculations. There is an acknowledgment of differing interpretations regarding the proportionality of changes in dimensions.
Participants are working under the assumption that the volume of the wire remains constant during the stretching process, which influences their calculations of resistance.
discoverer02
My answer for this problem doesn't agree with the answer in the back of my textbook book:
A wire with a resistance R is lengthened to 1.25 times its original length by being pulled through a small hole. Find the resistance of the wire after it has been stretched.
R = pL/A
p = resistivity
L = length
A = area of a cross section perpendicular to the length
r = radius
R1 = pL1/A1
L2 = 1.25L1 so r1/r2 should equal 1.25 right.
The decrease in radius should be proportional to the increase in length.
So r2 = r1/1.25
Therefore R2 = p(1.25L1)/[pi](r1/1.25)^2 = R1(1.25*1.56) = 1.95R1
The answer in the back of my textbook is R2 = 1.56R1
Where have I gone wrong?
Thanks
Should it? How would you go about proving this?
I'm assuming it's proportional. If it's not then I'm lost
Volume is constant, and volume is L*A, not L*r
You're right. Stupid me!
The area would have to shrink proportionally: A2 = A1/1.25 so R2 = 1.25*1.25R1 = 1.56R1.
Thank you very much for the help. :smile:
  • · Replies 23 ·
