Calculating the error of a experimental results
The discussion centers on calculating the error in the torsional rigidity value (C) derived from an experiment involving torsional oscillations of a disk. The formula used is [2Pi^2M(R^2+r^2)]/(t2^2-t1^2)=C, where M is the mass, R and r are the outer and inner radii, and t1 and t2 are the average oscillation times. The user, Dan, successfully calculated the error using the propagation of uncertainty method, specifically applying the formulas for error in MR^2 and Mr^2. Dan confirmed that his final error calculation was accurate, affecting the significant figures of his results.
  • Understanding of torsional oscillations and their significance in physics.
  • Familiarity with error propagation techniques in experimental physics.
  • Knowledge of basic calculus and algebra for manipulating formulas.
  • Experience with measurement uncertainties and standard deviation calculations.
  • Study error propagation in physics experiments, focusing on the method of least squares.
  • Learn about torsional oscillation experiments and their applications in material science.
  • Explore advanced statistical methods for analyzing experimental data.
  • Investigate the impact of measurement precision on experimental results and reporting.
Students and researchers in physics, particularly those involved in experimental mechanics, as well as anyone interested in understanding error analysis in scientific measurements.
dannyR
hello everyone, I've completed a experiment regarding torsional oscillations to determin the tortional ridgity in two types of wire. The final result is about what is to be expected but I am having trouble in calculating the error in my C " torsional ridigity" value.
the experiment was done by a torquing a disk of mass M connected to the end of the wire where R is the outer radius and r is the inner radius of the disc t2,t1 are the average times of the oscillations t1 being one mass and t2 being 2 masses this is to eliminate the unknown moment of inertia of the connecting bolt used to connect the disc to the end of the wires.
so to calculate the error in c when R,r,M,t1and t2 all have small errors due to measurments either reading errors or stdevp/N^0.5 in the case of the T the periods.
i have been calculating the error in MR^2 then Mr^2 using
(dM/M)^2+2(dR/R)^2=(dmR^2/mR^2)^2=(dx/x)^2, (dx/x) for simplicity x=mR^2
(dM/M)^2+2(dr/r)^2=(dmr^2/mr^2)^2=(dy/y)^2
then to add these two errors would i get:
using dQ^2=dx^2+dy^2=x^2[(dM/M)^2+2(dR/R)^2]+y^2[(dM/M)^2+2(dr/r)^2],
where dQ would be the total error in the top line of the fraction of the formula
the bit I am unsure about is when changing (dx/x)^2 to just dx^2 let's say (dx/x)^2=Z would the dx^2 to be =x^2*Z
can someone please comment if i am corrrect so far and if not please point me in the right direction as I am adament to get this correct as it is vital i learn to do this for myself.
Thanks a lot just for reading. Dan:)
It's ok i continued with what i was doing and my error came out to be about right, effecting the the last numbers of significant figures.
Thanks a lot dan
