Volume of a substance (in a circle)
  • Context: Undergrad
  • Thread starter Thread starter ozone
    Circle Volume
The discussion centers on calculating the volume of crude oil in a circular slick using the density function δ = 6400e^(-κ/4) gallons per square mile. The original poster attempted to integrate using the area formula Area = 2(pi)(y)(x) but was advised that the correct approach requires using polar coordinates. The correct integral setup is \iint_R 6400e^{-\sqrt{x^2+y^2}}\, dydx, where R represents the circular disk within a 5-mile radius from the center.
  • Understanding of integration techniques in calculus
  • Familiarity with polar coordinates
  • Knowledge of density functions and their applications
  • Basic geometry of circles and areas
  • Study integration in polar coordinates
  • Learn about density functions in physical applications
  • Explore advanced calculus techniques for multivariable functions
  • Practice problems involving volume calculations in circular regions
Students preparing for math exams, particularly those studying calculus and applications of integration, as well as educators teaching these concepts.
ozone
Hi I just want to check that I am doing this math problem correctly. We were given a density function for review for an upcoming math test. We were then asked to find the volume in a circular radius given this density function. I will post the exact problem now then explain the steps I went through to solve it.
θ
The density of a crude oil in a circular slick on the surface of the ocean κ miles from the center is given by δ = 6400e^(-κ/4) gallons per square mile. Find the total amount of oil within 5 miles of the center of the slick
I decided to integrate the function with the equation Area = 2(pi)(y)(x)
Obviously I picked our density function for y and just plain x for x. The integration was slightly complex but I could handle that. I just want to make sure I picked the right function.
Thank you.
θ
Thank you.
You didn't. The density depends on the distance from the center. If the center is (0,0) then your [itex]k =\sqrt{x^2+y^2}[/itex]. So your integral should look like
[tex]\iint_R 6400e^{-\sqrt{x^2+y^2}}\, dydx[/tex] where R is your circular disk. You would want to set that up in polar coordinates to work it.
  • · Replies 24 ·
