Projectile Motion (Guy commiting suicide)
The discussion centers on calculating the time it takes for Bob to reach the ocean after running off a cliff at a horizontal velocity of 4.2 m/s from a height of 110 meters. Using the equation Y = Vo + 1/2at², where Y represents height, Vo is the initial vertical velocity (0 m/s), and a is the acceleration due to gravity (-9.8 m/s²), the solution yields a time of approximately 4.74 seconds for Bob to hit the water. The calculation is confirmed to be accurate, emphasizing the importance of understanding projectile motion in physics.
  • Understanding of basic kinematics in physics
  • Familiarity with the equations of motion
  • Knowledge of gravitational acceleration (9.8 m/s²)
  • Ability to perform square root calculations
  • Study projectile motion in two dimensions
  • Learn about the effects of air resistance on falling objects
  • Explore advanced kinematic equations for varying initial velocities
  • Investigate real-world applications of projectile motion in sports and engineering
This discussion is beneficial for physics students, educators teaching kinematics, and anyone interested in understanding the principles of projectile motion and its calculations.
maxtheminawes
Bob has reached the special time in his life and runs horizontally off the edge of a cliff at 4.2 m/s. If the top of the cliff is 110m above the surface of the ocean, how long does it take Bob to reach the water?
Y=volt+1/2at^2
Y=height
t=time
Vo=initial velocity
-110=0+1/2(-9.8)t^2
t= sqrt of((-110)/(1/2(-9.8)))
t=4.74secs
This is morbid. I hope Bob can swim, and also he has got secretly a parachute, just for the case he changes his mind during the fall. He has enough time, that you calculated correctly.
ehild
28K
