Do I Need My Own Antiparticle to Calculate D^0 Decay to K^++π^-?
  • Context: Graduate
  • Thread starter Thread starter KBriggs
    Decay
The discussion revolves around the decay process of the D^0 meson into K^+ and π^-. Participants explore the requirements for constructing a Feynman diagram for this decay, particularly whether the D meson is its own antiparticle and the implications of this on the decay process.
  • One participant questions whether the D meson is its own antiparticle, specifically asking if |\bar{u}c\rangle = |u\bar{c}\rangle.
  • Another participant corrects the decay process, stating that the decay is actually D^0 → K^- + π^+, suggesting the consideration of an anti-D^0 instead.
  • A participant proposes the idea of changing D to anti-D by having the constituent quarks exchange a gluon, raising the possibility of the decay proceeding from the antiparticle.
  • Cabibbo suppression is mentioned as a factor affecting the decay, with one participant noting that the decay in question is doubly Cabibbo suppressed.
  • A later reply discusses the possibility of the c quark decaying into a d quark and a W^+ meson, which then decays into u and anti-s, questioning the likelihood of this decay compared to the previously mentioned one.
  • One participant expresses a lack of understanding of Cabibbo suppression and seeks resources for further explanation.
Participants do not reach a consensus on whether the D meson is its own antiparticle, and there are competing views regarding the decay processes and the role of Cabibbo suppression.
There are unresolved assumptions regarding the nature of the D meson and the implications of Cabibbo suppression on the decay processes discussed. The discussion also references specific decay modes without fully exploring their implications.
KBriggs
I am trying to work out the Feynman diagram for the decay
[tex]D^0\to K^++\pi^-[/tex]
But I can't seem to get it unless the D meson is its own antiparticle. Could someone tell me if this is the case? Ie, is [tex]|\bar{u}c\rangle = |u\bar{c}\rangle[/tex]?
Thanks
That's because the decay is actually D0 → K- + π+. Maybe you want to start with an anti-D0
No, the question gives three decays, one of which is the one you posted and another is the one I posted.
Could I change D to anti-D by having the two constituent quarks exchange a gluon, so that the decay I posted would then proceed from the antiparticle?
See for example decay modes 42 and 213 here: http://pdg.lbl.gov/2008/listings/s032.pdf
Do you know what Cabibbo suppression is? That decay is doubly Cabibbo suppressed. That should help you.
Update: seem to work if the c decays into d and a W^+ meson, which then decays into u and anti-s
any problems there?
this decay is apparently the much less likely than the one you posted. Why is that?
EDIT: I don't yet know what cabibbo suppression is. Do you know of a resource that explains it? Google turns up a lot of scholarly stuff that assumes I know it already.
