Calculating free-fall acceleration of other planets
The discussion revolves around calculating the free-fall acceleration on the surface of planet Roton based on the orbital characteristics of a satellite. The problem involves understanding gravitational forces and orbital mechanics.
  • Participants explore various methods to determine the mass of Roton and its effect on calculating free-fall acceleration. There is discussion about whether mass is necessary for the calculations and how to correctly apply the relevant equations.
Some participants have provided guidance on the correct use of formulas and questioned the necessity of mass in the calculations. Multiple interpretations of the problem are being explored, particularly regarding the relationship between orbital velocity, radius, and acceleration.
There is a focus on ensuring the correct parameters are used in the equations, with some participants noting confusion about which radius to apply in different contexts. The problem is framed as a multiple-choice question, which adds a layer of complexity to the participants' reasoning.
menglish20
Here is the text of the question:
"A satellite circles planet Roton every 2.8 h in an orbit having a radius of 1.2 X 10^7 m. If the radius of Roton is 5.0 X 10^6 m, what is the magnitude of the free-fall acceleration on the surface of Roton?"
v=d/t
M= [(Ve)^2*R]/(2G)
a=GM/r^2
This is presented as multiple choice, and I've been able to find the answer as 27 m/s^2 but I haven't been able to figure it out on my own.
What I tried to do is find the mass of Roton using the orbit speed.
I took the distance traveled by the satellite, 2*pi*1.2e7, and diving it by the time of one complete orbit, 2.8 hr or 10080 s. I calculated this velocity as 7479.98 m/s.
To find mass, I used the second formula I listed, and used the radius of Roton as R. I'm not sure if this is correct. I used this mass in the third formula, using the sum of Roton's radius plus the orbit radius. I think this may also be incorrect. I got an answer that was significantly different than the multiple choice answers provided. Can someone steer me in the right direction?
No, it's not correct. The orbital radius should have been used as R.
Indeed. You should have used just Roton's radius.
If you know the velocity and the orbit radius you can find the acceleration, no need for mass
I had a guess that mass isn't needed but I couldn't figure out a way to calculate acceleration without it. Am I overthinking this? Given velocity and orbit radius, could you use:
Fc= m*ac, so ac=v2/r ?
If so, this is way easier than I thought.
Edit: I don't think this is correct. First, I don't even know if that equation is true, and if so, the ac would not be the free-fall acceleration, but the centripetal acceleration that maintains the satellite in a circular path.
Edit 2: I've figured it out! You do indeed need mass. Calculate it using v=sqrt(GM/R). Then use the mass in the formula a=GM/R^2. The R in the first equation is the orbital radius and the R in the second is the radius of Roton. This may have been what Barakn was explaining but I was using the wrong formula for calculating the mass. Thanks for the help, Barakn and Zula!
You can calculate the mass, but it's not necessary. We know that M= Ve2*R/G (you typed out the formula wrong) and a = GM/r2. Substitute M into the second equation to get a = G * Ve2*R/(r2*G) = Ve2*R/r2. Everything performed in one calculation in which G and M have magically disappeared.
