Finding the concentration in a solution
  • Thread starter Thread starter morgan8222
    Concentration
The discussion revolves around determining the concentration of copper in a solution prepared from a penny, specifically focusing on the methods and calculations involved in finding this concentration. Participants explore definitions of concentration, the implications of dilution, and the necessary steps to analyze the copper content.
  • Homework-related
  • Some participants express confusion about the relevance of adding ammonium hydroxide to the copper nitrate solution in the context of finding copper concentration.
  • One participant suggests calculating the moles of copper in the 2 mL of 0.08 M copper nitrate solution to determine the concentration in the final 50 mL solution.
  • There is a discussion about whether the concentration refers to total copper or a specific form, such as tetraamminediaquacopper(II).
  • Participants mention that the total concentration of copper remains constant during dilution, as the number of moles does not change.
  • Several definitions of concentration are proposed, including mass per mass percentage and molar concentration, with some participants noting the complexity of determining concentration from a penny without dissolving it first.
  • One participant introduces the idea of using methods like spark spectroscopy for analysis without dissolving the penny, while others advocate for traditional wet methods like titration.
  • Clarifications about the meanings of weight/weight (w/w) and volume/volume (v/v) percentages are provided, with a request for further explanation on these terms.
Participants do not reach a consensus on the best method for determining copper concentration or the definitions of concentration itself. Multiple competing views and uncertainties remain regarding the appropriate approaches and definitions.
Some participants highlight that determining concentration from a penny requires the copper to be dissolved in a solution, while others suggest alternative analytical methods that do not require dissolution. There are also unresolved questions about the specific forms of copper being measured and the definitions of concentration used in the discussion.
This discussion may be useful for students and researchers interested in analytical chemistry, particularly those exploring methods for determining metal concentrations in solutions and the definitions of concentration in various contexts.
morgan8222
I am doing a lab to find the concentration of copper in a penny. I am confused on how to find the concentration of copper in each solution I prepared. One solution for example:
2 ml of 0.080 M Cu(NO3)2
add 2 ml of concentrated ammonium hydroxide
dilute solution to 50 ml
Can someone help me out?
What is the definition of concentration?
I'm confused. You have to find the concentration of copper in a penny. What has this got to do with adding 2 mL of NH4OH to Cu(NO3)2? Anyhow, you want to know how to find the concentration of copper in that 54 mL solution you prepared. Firstly, figure out how much copper is in 2 mL of 0.08M copper nitrate solution. M means moles per liter. This means there are 0.08 moles of copper nitrate in a liter of that solution. You only have 2 mL so how many moles are in that?
What 54 ml solution?
Concentration of copper, or of tetraamminediaquacopper(II)? Or total copper in any form?
It is a total of 50 ml. Water is added to the solution until it is 50 ml.
0.080 M Cu(NO3)2 = 0.00016 moles in 2 ml
"Total concentration of copper" in this solution I prepared.
Is there any other source of copper?
Then it is simple dilution. Number of moles of copper doesn't change, it is constant - just the volume changes.
Note: it looks messy, as these are two cross posted threads merged.
Concentration can be defined as the measure of amount of substance dissolved in known volume of a given solution. It is expressed in (amount in grammes of the substance per cubic centimete of solution when the mass concentration is concerned) gcm-3. It can also be expressed as in (amount in mole of substance per cubic decimeter of solution if the molar concentration is required ) moldm-3.
I can infer from this defination that it is not easy to determine the concentration of a substance say copper in a penny unless the copper is disolved in a given volume of a solution. Your views are welcome. Thank you.
Not bad, but not perfectly OK as well. Concentration can be also expressed as mass per mass (say 10% w/w NaCl solution means in each 100 g of solution there is 10 g of NaCl - whatever the volume is). It can be also expressed in terms of molar fraction, moles per mass of solvent (it is known as molality then) and so on.
See above. There are other ways of expressing concentration that will be perfectly suitable to copper in penny. Mass per mass percentage would be my choice.
You have sold me again! What does that w/w denote?
But like what I just said if any person want to determine the concentration of copper in a penny; at least that person have to dissolve that penny in a solution before it will be easy to find the concentration of copper in it. How about that?
You mean for analysis? Yes - and no. If the coin has identical composition in all its volume, there are methods (I am not sure about English name - something like spark spectroscopy, spark atomic emission spectroscopy) that can be used to analyze composition just by locally heating the surface with electric arc. But the simplest approach is to dissolve the sample and use some wet method like titration, such an approach doesn't require any costly hardware.
You have sold me again! What does that w/w denote? You have not answered my question on yet. Please tell me what that w/w mean so that I will be following. Alright!
w/w = weight/weight or mass percentage
v/v = volume/volume or volume percentage
See concentration lectures for more details.
