Calculating Induced EMF in a Conducting Loop with Changing Magnetic Field
The discussion focuses on calculating the induced electromotive force (EMF) in a conducting loop with a half-circle radius of 0.20m, subjected to a time-varying magnetic field defined by B(t) = 4.0t² + 2.0t + 3.0 Teslas. The loop, which has a resistance of 2.0 Ohms, is connected to an ideal battery with an EMF of 2.0V. To find the induced EMF, the equation -dflux/dt is utilized, where flux is determined by the product of the magnetic field and the area of the half-circle. The current in the loop at t = 10 seconds can be calculated using Ohm's law, I(t) = V/R, where V is the total EMF in the loop.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Knowledge of calculating magnetic flux
  • Familiarity with Ohm's Law (V = IR)
  • Basic concepts of electric circuits and components
  • Study the application of Faraday's Law in varying magnetic fields
  • Learn how to calculate magnetic flux for different geometries
  • Explore the relationship between induced EMF and current in circuits
  • Investigate the effects of resistance on current flow in electrical circuits
Students studying electromagnetism, physics educators, and electrical engineering professionals seeking to deepen their understanding of induced EMF in circuits with changing magnetic fields.
Moore65
Here is a bonus question that I was given yesterday. I am completely at a loss of what to do. Any suggestions?
A conducting loop with a half circle of radius r=0.20m and 3 straight sections. The half circle lies in a uniform field B that is directed out of the page. The magnitude of B as a function of time is given by B(t) = 4.0t^2 + 2.0t + 3.0 where B is in Teslas and t is in seconds. An ideal battery with EMF E=2.0V is connected to the loop. The loop has a resistance of 2.0 Ohms.
a) Find the magnitude and direction of the EMF induced in the loop.
b) What is the current in the loop at t = 10 seconds?
just use the equation for induced emf: -dflux/dt.
flux = B(t)*area of half circle
add this emf as a function of time to the battery emf of 2.0V. I think you add, at least. they tell you the B field is directed out of the page, but they don't tell you which way the battery is connected... anyway, add 2 + (-dflux/dt) and this is your emf in the loop as a function of time. then use v = ir to calculate i(t).
But how do I find the direction of the EMF?
