Simple control circuit for a dc motor to power a conveyor for 5 seconds
This discussion focuses on designing a simple control circuit for a DC motor to power a conveyor belt for a duration of 5 seconds. The user requires a steady speed for the conveyor, which is driven by a pulley with a radius of 1 inch and a total length of 48 inches. The calculated power requirement at the pulley is 2.6 Watts. The conversation emphasizes that while constant voltage can be supplied to the motor, the speed may decrease due to the motor's resistance and the current draw under load.
  • Understanding of basic electrical concepts such as voltage and current
  • Familiarity with DC motor operation and characteristics
  • Knowledge of simple circuit design for motor control
  • Basic calculations for power requirements in electrical circuits
  • Research simple DC motor control circuits using constant voltage
  • Learn about motor resistance and its impact on performance
  • Explore methods for calculating power requirements in motor applications
  • Investigate the use of motor controllers for precise speed regulation
Hobbyists, electrical engineers, and anyone interested in basic motor control and circuit design for conveyor systems.
maxi9
I am a hobbyist, and I am not too familiar on to how to run motors. Can someone help me design a simple circuit that drives a dc motor on pulley drive of a conveyor belt. I only need a steady speed, I am not changing speeds. The conveyor belt has to stay on for 5 seconds after a switch is turned on. The belt is about 48 inches long, the radius of the pulley is 1 inch. I have calculated the power at the pulley to be 2.6 Watts.
Thank you in advance,
Regards,
The speed of a motor is primarily dependent on the voltage. The torque of a motor is dependent on the current the motor draws. Since there is some resistance in the motor, that resistance will drop a small voltage depending on the current through the motor. This means that even if you supply constant voltage to a DC motor, its speed will drop slightly due to the increased current needed for an increased load.
Simple motor controllers where precise speed control is not needed just supply constant voltage to the motor. If precise speed control is needed then the current through the motor is also sensed and is used to increase the voltage to the motor to compensate for the voltage lost to motor resistance.
  • · Replies 31 ·
  • · Replies 18 ·
