Extremely hard vectors/geometry problem: Find the centre of a sphere
  • Thread starter Thread starter Nikitin
    Hard Sphere
The discussion focuses on solving a geometry problem involving two planes, α and β, defined by the equations x-2y+z=2 and 2x+y+z=5, respectively. The task is to find the center of a sphere that touches both planes at points A=(11,9,9) and B=(4,-14,-1). The user has established that the vectors PB and PA are perpendicular to the line of intersection and the normal vectors of the respective planes. However, they encountered difficulties in deriving the coordinates of the sphere's center, S, using a parametric function.
  • Understanding of vector geometry and perpendicularity in three-dimensional space.
  • Familiarity with parametric equations and their applications in geometry.
  • Knowledge of plane equations and normal vectors in 3D geometry.
  • Ability to perform algebraic manipulations involving distances and coordinates.
  • Review the derivation of parametric equations for lines and planes in three-dimensional space.
  • Study the properties of perpendicular vectors and their geometric implications.
  • Explore methods for calculating distances between points and planes in 3D geometry.
  • Investigate the use of simultaneous equations to solve for unknown coordinates in geometric problems.
Students and educators in geometry, particularly those tackling advanced problems involving spheres and planes, as well as anyone interested in enhancing their understanding of vector mathematics and spatial reasoning.
Nikitin
Plane α: x-2y+z=2. Plane β: 2x+y+z=5
Point P= (0,1,4) is on the line of intersection, with directional vector L, between the two planes.
A sphere is touching plane alpha at point A and plane beta at point B. Show that PB is perpendicular to L and the normal vector of plane Beta, and that PA is perpendicular to L and the normal vector of plane Alpha. Find the centre of the sphere, point S.
point A=(11,9,9) point B= (4,-14,-1).
I found the line of intersection, which contains Point P. I also confirmed that vectors PB & PA are both perpendicular to the line of intersection, and PB is perpendicular to the normal vector of plane alpha while PA is perpendicular to the normal vector of plane beta. This I was ordered to do by the assignment.
I set up a parametric function. The centre coordinates are: x,y,z. Using some geometry I set up a parametric function where x= 7t y=21t+1 z=4.
I then figured that the radius of the circle equals= (11-x)^2 + (9-y)^2 + (9-z)^2 = |SA| = |SB| = (-4-x)^2 + (14-y)^2 + (-1-<)^2
Well, I tried to do the algebra, substituting x with 7t, y with 21t+1 and z with 4 but I just ended up with 0t=0.
Can you guys help me?
uhh, sorry a few typos:
1) radius of the circle = (11-x)^2 + (9-y)^2 + (9-z)^2 = |SA| = |SB| = (-4-x)^2 + (14-y)^2 + (-1-z*)^2
* replaced < with z.
2) I put the coordinates of point S, the centre of the sphere, as X, Y, Z.
bump? anyone knows? and why was the post editing feature removed?
  • · Replies 16 ·
  • · Replies 21 ·
