Proving a Claim in Ticcati's Red QFT Textbook: Seeking Advice and Hints
  • Context: Graduate
  • Thread starter Thread starter MathematicalPhysicist
The discussion revolves around proving claims made in Ticcati's "Red QFT" textbook, specifically regarding the uniqueness of the position operator and its relationship with the momentum operator within the framework of quantum field theory. Participants seek clarification on the implications of certain axioms and the mathematical form of operators involved.
  • Some participants inquire about proving claims from Ticcati's textbook, particularly regarding the uniqueness of the position operator and its expression in terms of momentum operators.
  • One participant questions the meaning of assuming an operator is given with respect to a specific basis, indicating confusion about the relevance of basis states in the axioms for the position operator.
  • Another participant discusses the implications of Axiom 3, which relates to the transformation properties of operators under rotations, and how it leads to the conclusion that a function of momentum must take a specific form.
  • There is a debate about whether the inverse of a rotation matrix commutes with unitary representations, with some arguing that it is reasonable to assume this while others express uncertainty.
  • Participants explore the relationship between the components of the momentum vector and their invariance under rotations, with one noting that while the components are not invariant, the square of the momentum is.
  • One participant suggests that the form of a function related to momentum must be derived from its transformation properties, but acknowledges the difficulty in proving this rigorously.
Participants express varying levels of understanding regarding the implications of axioms and the mathematical forms of operators. There is no consensus on the proof of the claims, and multiple competing views and uncertainties remain throughout the discussion.
Participants note limitations in their understanding of the axioms and the mathematical steps required to derive certain conclusions. There is also mention of the need for further exploration of specific cases to clarify the relationships between operators.
Does anybody know how prove the claim in my question here:
http://theoreticalphysics.stackexchange.com/questions/643/a-question-from-ticcatis-red-qft-textbook
thanks, any hints?
I have another question from the same textbook.
In Remark 1.6.4 he starts to show that the position operator is unique, so we take two such operators [itex]X,Y[/itex], and he assumes that [itex]Y[/itex] is given wrt the basis [itex]|k>[/itex]. The canonical commutation must be satisified for both of them, then [itex]P_r[/itex] commutes with [itex]X_s-Y_s[/itex] (which thusfar I follow). Therefore assuming that any operator can be expressed as a function of both [itex]X_r,P_r[/itex], [itex]Y_r[/itex] must be of the form [itex]X_r+f_r(P)[/itex], now the thing that I don't understand is that he argues Axiom 3 implies that [itex]f_r(P)[/itex] is of the form [itex]g(|P|^2)P_r[/itex], where axiom 3 tells us that if [itex]R[/itex] is a space rotation, then [itex]U(R)^{\dagger} X U(R) = RX[/itex] where [itex]U(R)[/itex] is the unitary representation of [itex]R[/itex] in Poincare group.
Any help as to why Ax 3 implies it?
I don't see it.
thanks, any hints?
That guy Pavel solved it for you.
I don't understand what this means. I understand that |k> is a momentum eigenket, but that doesn't help. The exact statement in the book is "Assume that [itex]\bar Y[/itex] is the position operator with respect to the basis [itex]|\bar k\rangle[/itex]". I still don't get it. There's no basis involved in the axioms for the position operator.
...now the thing that I don't understand is that he argues Axiom 3 implies that [itex]f_r(P)[/itex] is of the form [itex]g(|P|^2)P_r[/itex], where axiom 3 tells us that if [itex]R[/itex] is a space rotation, then [itex]U(R)^{\dagger} X U(R) = RX[/itex] where [itex]U(R)[/itex] is the unitary representation of [itex]R[/itex] in Poincare group.
The equality in axiom 3 is [itex]U(R)^\dagger\bar X U(R)=R\bar X[/itex]. This has to mean [itex]U(R)^\dagger X^r U(R)=R^r_s X^s[/itex]. So [itex]Y^r=X^r+f^r(\bar P)[/itex] implies [itex]R^r_sY^s=R^r_sX^s+U(R)^\dagger f^r(\bar P)U(R)[/itex]. Multiply this by [itex](R^{-1})^t_r[/itex], and the result is [itex]Y^t=X^t+U(R)^\dagger(R^{-1})^t_r f^r(\bar P) U(R)[/itex]. So [tex]f^r(\bar P)=Y^r-X^r=U(R)^\dagger(R^{-1})^r_s f^s(\bar P) U(R).[/tex] Does this help, or is this the point where you are stuck?
Do you assume that [itex]R^{-1}[/itex] commutes with [itex]U(R)^{\dagger}[/itex]?
Assuming you do, I still don't see how from your last line you get that [itex]f_r(P)[/itex] equals [itex]g(|P|^2) P_r[/itex].
Edit: I guess it's reasonable to argue that R and its inverse will commute with their Poincare representations, I think.
There's no need to assume it. [itex]R^r_s[/itex] is the number on row r, column s, of the rotation matrix R. When it appears as a factor in a formula involving operators, it should be interpreted as the real number [itex]R^r_s[/itex] times the identity operator, and the identity operator commutes with everything.
I assume that you can see that the converse of what you want to prove is true, i.e. that if [itex]f^r(\bar P)[/itex] is what you need it to be, then the last equality of my previous post holds. It's harder to explain why [itex]f^r(\bar P)[/itex] must be of that form. I haven't worked it out, but I think it's essential that the last equality in my previous post is supposed to hold for all R. Maybe it will help to consider a few specific choices of R.
I think I understand why if [itex]f^r(\bar{P})=g(|P|^2)P^r[/itex] then it satisfies the relation you wrote with the unitary representations, it's because the 4-momentum vector is invariant under space rotations.
Not sure about the converse.
P.S
Appreciate your help. :-)
[itex]\bar P[/itex] is the 3-momentum vector. Its components aren't invariant under rotation, so the components of the 4-momentum vector aren't either. But [itex]|\bar P|^2[/itex] is invariant, because a rotation by definition doesn't change the norm of any vector. Edit: To be more precise, in a notation that puts all indices downstairs (because the "one upstairs, one downstairs" notation makes it hard to handle transposes and inverses), [tex]U(R)^\dagger\bar P^2U(R)=U(R)^\dagger P_r U(R)\ U(R)^\dagger P_r U(R)=R_{rs}P_s R_{rt} P_t=(R^T)_{sr}R_{rt}P_sP_t=\delta_{st}P_sP_t=P_sP_s=\bar P^2.[/tex] I don't think there's an easy way to prove that [itex]f^r(\bar P)[/itex] must be of the form [itex]g(|\bar P|^2)P^r[/itex]. I also don't think there's an easy way to prove that [itex]Y^r-X^r[/itex] must be of the form [itex]f^r(\bar P)[/itex]. Ticciati doesn't even explain what that means. I'm going to think about this some more, but I can't guarantee that I will come up with something useful.
The non-rigorous argument for the form of [itex]f^r(\bar P)[/itex] is that when you multiply components of [itex]\bar P[/itex] together and sum over repeated indices, the result isn't going to transform under rotations like a 3-vector unless r is the only index left. Terms like [itex]P^rP^s P_s P^t P_t[/itex] are OK, but terms like [itex]P^r P^s[/itex] aren't.
  • · Replies 167 ·
12K
  • · Replies 18 ·
  • · Replies 34 ·
  • · Replies 473 ·
34K
  • · Replies 22 ·
