Assume light travels from point a to b. Find the total time to get from a to b
The discussion revolves around the problem of determining the total time taken by light traveling from point A to point B, considering different velocities above and below a boundary line. The context involves applying principles from optics and calculus, specifically relating to Snell's Law.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the formulation of the time function T(x) and its derivative T'(x). There are attempts to relate the angles of incidence and refraction to the velocities of light in different media. Questions arise regarding the correct interpretation of the sine functions and the setup of the equations.
The conversation is ongoing, with participants providing insights into the mathematical relationships involved. Some guidance has been offered regarding the correct use of sine functions and the implications of setting T'(x) to zero. There is recognition of the need to clarify the goal of finding the total time and how it relates to the derived equations.
Participants note the importance of a diagram that was initially missing, which is crucial for understanding the geometric relationships in the problem. There is also mention of potential confusion regarding the notation used in LaTeX formatting.
NWeid1
Suppose that light travels from point A to point B as shown in the figure/ Assume that the velocity of light above the boundary line is v1 and the velocity above the boundary line is v2. Find the total time T(x) to get from point A to point B, Write out the equation T'(x) = 0, replace the square roots using the sines of the angles in the figure and derive Snell's Law [tex]\frac{sinθ_1}{sinθ_2} = \frac{v_1}{v_2}[/tex]
Here is the work I've done so far.
[tex]T(x) = \frac{\sqrt{1+x^2}}{v_1} + (-\frac{\sqrt{1+(2-x)^2}}{v_2})[/tex]
[tex]T'(x) = \frac{1}{v_1\sqrt{(1+x^2)}} - \frac{1(x-2)}{v_2(\sqrt{(1+(2-x)^2)}} = 0[/tex]
[tex]T'(x) = \frac{1}{v_1\sqrt{(1+x)^2}} = \frac{x-2}{v_2\sqrt{1+(2-x)^2}}[/tex]
And I know I have to get
and I replaced the fractions with sines but the (x-2) on the right side of the equation messes up the formula, so now I'm confused.
Also! Is my latex working for you guys? What did I do wrong? lol
You confused the parser by using bv code (all those and tags) inside the [tex]tag.[/tex]
I think you have forgotten to find x so that T(x) is a minima.
(assuming x is the point the light hits the interface, A=(0,1) and B=(2,-1)?)
Wouldn't making T'(x) = 0 be finding a minima?
And what is the right way to type up this function then? haha
Oh okay, so finding where the function = 0 would be finding the min. so before i use the sine functions I should solve for x?
Sorry, misread .. you did do that step.
You have a pic with two triangles, and the normal drawn in and the angles?
Then, assuming A=(0,1) and B=(2,-1):
[tex]\sin(\theta_1) = \frac{x}{\sqrt{1+x^2}}[/tex]
you do it for [itex]\sin(\theta_2)[/itex]
Aside:
Sub and superscripts in LaTeX are like this: x_1^{23}would be [itex]x_1^{23}[/itex]
For more than one character you have to enclose them in curly brackets.
Also, I am soooooo stupid. There is a picture I forgot to attach. Wow, sorry anyone who was confused by this lol. The pic is up now.
No worries, I stuffed up the sine in prev post.
You should be able to find the other one now.
In your last two equations, how come (x-2) instead of (2-x)? How come you get a 1 in the numerator of the first term in T' and not an x?
In the last equation, as written, does not make sense ... presumably you mean:
[tex]T'(x) = 0 \Rightarrow \frac{x}{v_1\sqrt{(1+x)^2}} = \frac{2-x}{v_2\sqrt{1+(2-x)^2}}[/tex]
Why would
[tex]sin(\theta_1) = \frac{x}{\sqrt{1+x^2}}[/tex]
and not just
[tex]sin(\theta_1) = \frac{1}{\sqrt{1+x^2}}[/tex] ?
Look at the diagram.
By definition: [itex]\sin \theta = \frac{O}{H}[/itex]
The hypotenuse has length [itex]\sqrt{1+x^2}[/itex] because the opposite side has length [itex]x[/itex].
(the angle is pointing the other way to how you are used to - [itex]1/\sqrt{1+x^2} = \cos \theta[/itex].)
Ooooh ok I got it. So
[tex]\sin(\theta_2) = \frac{2-x}{\sqrt{1+(2-x)^2}}[/tex]
? or would it be negative
Ok no I got it it's [tex]\sin(\theta_2) = \frac{2-x}{\sqrt{1+(2-x)^2}}[/tex]
so then I get [tex]\frac{\sin{\theta_1}}{v_1} = \frac{\sin{\theta_2}}{v_2}[/tex]
which means we would get
[tex]\frac{sin{\theta_1}}{sin{\theta_2}} = \frac{v_1}{v_2}[/tex]
But now I am confused after reading it again and again...What am I exactly trying to find? The total time, right? So how do I use this formula it asked me to get to find the total time? Lol, I'm lost right now
Weren't you supposed to derive Snell's Law?
Isn't this what you have?
Well done!
An observation and a lesson:
In general, light always takes the path of least time. This is just a specific example.
Get the geometry right, everything else takes care of itself.
Ok, so, how can I show that this will be the minimum time to travel from A to B?
What did you find T'(x) for?
a minimum. "Minima" is the plural of "minimum".
Haha sorry, didn't mean to break the calculus rules...-.-
