Simple Harmonic Motion (displacement function)
The discussion revolves around the topic of simple harmonic motion (SHM), specifically focusing on the displacement function and the use of sine and cosine functions in its representation. Participants are exploring the implications of the phase angle in the equations for SHM.
  • The original poster questions when to use sine versus cosine in the displacement function and seeks clarification on the phase angle, denoted as Φ. Some participants note the equivalence of sine and cosine functions and discuss the significance of initial conditions in determining the appropriate function to use.
Participants are actively engaging with the concepts, with some providing insights into the conditions under which sine or cosine may be preferred. There is a recognition of the phase angle's role, and some guidance has been offered regarding its determination based on initial conditions.
One participant introduces a specific problem involving calculations of acceleration and velocity in SHM, prompting further exploration of how to approach such questions. This indicates a potential shift towards applying the discussed concepts to practical problems.
yoohyojinn
I learned that in simple harmonic motion,
the displacement fuction is
x(t) = A sin(ωt + Φ)
or
x(t) = A cos(ωt + Φ)
but when do you use sine function or cosine function?
can I use whatever I want whether a sine or cosine function?
And what's that Φ in the equation?
Is it a quantity called a phase angle??
Note that cos(x) = sin(x + pi/2)
You can use both the sine and cosine functions for the displacement during SHM. You can call Φ phase angle or rather phase constant, and you can determine it form given initial conditions.
If the SHM starts with maximum displacement the cosine function is convenient to use, as x=Acos(ωt) is maximum at t=0, so Φ=0.
In the case when the SHM starts from zero displacement by giving the object some velocity, it is easier to use x=Asin(ωt).
ehild
A boby moves in S.H.M with a amplitude of 30mm and a frequency of 2.0Hz. Calulate the values of
(a) the acceleration at the centre and extremeties.
(b) the velocity at these positions
(c) the velocity and acceleration of a point between the centre and extremity of the oscillation
how would i approach a question like this?...
  • · Replies 51 ·
