Make Constructor for Standard Class
  • Thread starter Thread starter TylerH
    Class Standard
The discussion revolves around creating a constructor for a standard class in C++ that allows a user-defined class to be cast to a string using C++-style casting. Participants explore the implications of modifying standard classes, the use of conversion operators, and the potential pitfalls associated with type conversions.
  • One participant asks how to create a constructor for a standard class that allows casting a user-defined class to a string.
  • Another participant explains that making non-empty constructors is similar to making default constructors and provides an example of a custom constructor.
  • A participant clarifies that they want to know how to create a constructor for the string class, which is not possible without breaking standard compliance.
  • Some participants assert that you cannot add constructors to standard classes in C++ and suggest defining a custom class that utilizes standard classes instead.
  • One participant proposes adding a conversion operator to the user-defined class to facilitate casting to a string, while also noting that such practices may lead to unexpected type conversions.
  • A later reply provides an example of unexpected type conversions, illustrating a scenario where a character is mistakenly treated as a string.
  • Another participant questions the necessity of conversion operators and suggests that calling a method may be more appropriate in some cases.
Participants generally agree that you cannot modify standard classes in C++. However, there is disagreement regarding the use of conversion operators, with some advocating for their use and others cautioning against potential pitfalls.
Participants discuss the implications of using conversion operators, including the potential for unexpected type conversions and unnecessary copies of strings. The conversation highlights the importance of considering design choices in programming practices.
TylerH
How can I make a constructor for a standard class that accepts my class? For example, I have a class x and I want to make it possible to C++-style cast it to a string (ie "string(x)" rather than "(string)x"); how do I do that/what does the constructor function declaration look like?
Technology news on Phys.org
Hey TylerH.
Making non-empty constructors are the same as making default constructors: you just declare another constructor with your parameter list.
As an example:
Code:
#include <string> // Custom string class used as an example
class MyClass
     MyClass(); // Default constructor no arguments
     MyClass(string x); // New constructor takes in string
     virtual ~MyClass();
     string m_mystring;
MyClass::MyClass()
   // Blah blah
   m_myString = string();
// Custom constructor
MyClass::MyClass(string x)
   m_myString = string(x); // Copy string contents
// Destructor
MyClass::~MyClass()
   // Assume string destructor cleans up everything for string class
Also it depends on how you pass the parameter: either by reference (pointer, address) or by value (put the object on the stack).
I know how to make a constructor. I'm asking how I make one that allows me to cast my class to a string using C++-style casting, which requires that I somehow make a string constructor that accepts my class as a parameter. However, I don't know how to make a constructor for the string class, since I add my constructor to it's definition, because it's a standard class. (Actually, I could, but that would break the standard-ness and thus, defeat the purpose.)
For example:
Code:
#include <string>
using namespace std;
class X{
public:
     X(string s) : x(s) {}
     string data()
          return x;
private:
     string x
int main()
     X t("example"); // I know how to do this.
     string u = string(t); // I want to know how to do this.
     // u should be "example."
     return 0;
// This is my attempt. I get an error saying it isn't declared in string.
string::string(const X &x)
    *this = x.data();
You can't add constructors to a standard class in C++.
If you want to, you can define your own class that makes use of a standard class, in which you can define custom constructors.
What's the best way to allow my class to be casted to a string?
Ah well, you can add a conversion operator to your class.
Code:
class MyClass
   operator std::string() const { return x; }
   std::string x;
I have learned though that in good programming practices conversion operators should be avoided.
This is due to possibly unexpected type conversions.
Unexpected type conversions are an important pitfall in C++.
For this reason the standard std::string class does not have a conversion operator to a "const char *".
Instead it has a method named c_str().
Code:
class MyClass
   std::string x;
Thanks!
What do you mean "possibly unexpected type conversions"? Could you give an example?
For background, I'm using this in a dictionary library I'm writing. I'm using a trie. I'm using the conversion operator to allow casting from a trie node/dictionary entry to a string. IMHO, it makes sense to allow a dictionary entry to be casted to a string.
You're welcome! :smile:
Here's an example of an unexpected conversion:
Code:
#include <iostream>
#include <string>
class MyClass
public:
    MyClass(char ch) : m_str(1, ch) {}
    const std::string& toString() const { return m_str; }
private:
    std::string m_str;
int main(void)
    MyClass x = 2;
    std::cout << x.toString() << std::endl;
    return 0;
Suppose you expected the 2 to be converted to a string.
It didn't.
(What did it do?)
The std::string class is designed to disallow this sort of mistakes.
You seem to have a good justification for using a conversion operator and I would accept that as a code reviewer.
Consider though, whether it really helps your code.
How often does it happen that you need to convert a dictionary entry to a string?
And how bad is it to call a method?
Also note that the conversion operator makes an unnecessary copy of the string, whereas a method like the toString() method in my example can return a const-reference.
(I borrowed the name "toString" from java where that is a standard method.)
  • · Replies 36 ·
  • · Replies 36 ·
  • · Replies 36 ·
  • · Replies 23 ·
  • · Replies 18 ·
  • · Replies 31 ·
  • · Replies 23 ·
  • · Replies 89 ·
  • · Replies 35 ·
