| New Reply |
Hollow Metal disc loading - the needed thickness of the disc? |
Share Thread | Thread Tools |
| Dec11-11, 03:26 AM | #1 |
Hi,
how to calculate the limit of load you can place on the top of the circular plate with a quite big circular hole in it (OD 10 cm, ID 5 cm)? the question is how to calculate the thickness needed to bear 1 kg which is spread on the whole area (1 kg heavy object with the same shape as the plate, a hollow cylinder 10 cm x 5 cm x some height). The plate is in the air, supported by 3 bars on the ring of the plate. thank you for any help/advice! This is not a homework, I don't want to "get the solution" but be able to compute it for material I'd use than. picture http://s3.amazonaws.com/answer-board...bbef84bf5.jpeg |
| Dec11-11, 10:53 AM | #2 |
Roark's Formulas for Stress and Strain Chapter 11 has this.
| New Reply |
| Tags |
| bearing, disc, hollow, load, metal |
| Thread Tools | |
Similar Threads for: Hollow Metal disc loading - the needed thickness of the disc?
| Collision of an expanding disc with another disc. | Classical Physics | 3 | ||
| How much torque needed to turn a 1.2m disc | Mechanical Engineering | 9 | ||
| calculate the surface charge distribution on a metal disc | Introductory Physics Homework | 1 | ||
| Farday's Disc - Diameter of Disc | Introductory Physics Homework | 2 | ||
