Calculate the speed of the block
  • Thread starter Thread starter gunnar
    Block Speed
The discussion revolves around calculating the speed of a block connected to two metal disks acting as a pulley system. The original poster presents an equation for speed but expresses difficulty in applying it, suggesting a need for a relationship between the disks.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the mechanics of the disks and their motion, questioning the setup of the problem and the application of conservation of energy. There are discussions about the relationship between angular and linear speeds, as well as the correct interpretation of height in energy equations.
Some participants have provided insights into using conservation of energy and relating angular acceleration to linear acceleration. There is an ongoing exploration of the equations involved, with no explicit consensus reached on the final approach or solution.
Participants note the importance of defining the origin for potential energy and clarify the height difference relevant to the falling mass. The problem's constraints and the specific roles of the disks in the pulley system are also under discussion.
gunnar
Hi. I have a problem.
Two metal disks with different radius and different weight are welded together. The smaller disk has a string wrapped around it with a block on the other end. I have to calculate the speed of the block after 2 meters. I'm trying to use this equation: v=sqrt(2gh/1+M/2m) to solve this. Where M is the total mass of the disks and block while m is the mass of the block. This is not working. Do you guys know a way around this, I guess I need some kind of a relation between the two disks.
I don't understand the entire problem. How are the disks set in motion?
Are they allowed to roll on a table with the block hanging over a pulley at the end of the table? Or something else?
If I've understood correctly the two disks act as a pulley with the mass at the end of the string. If it is the case you can work it as a typical solid rigid problem calculating the angular acceleration and relating it with the linear acceleration of the mass. Then it becomes a "semi-free" fall problem.
Or you can take the simpler approach of conservation of energy:
Supposing the pulley is fixed so its potential energy remains constant, the initial energy of the system is
[tex]mgh_1[/tex]
and the final would be
[tex]\frac{1}{2}(I_1+I_2)\omega^2+\frac{1}{2}mv^2+mgh_2[/tex]
[tex]I_1[/tex] and [tex]I_2[/tex] are the moments of inertia of the disks.
you can relate [tex]v[/tex] and [tex]\omega[/tex] by [tex]v=\omega r[/tex]
where [tex]r[/tex] is the radius of the disk where the string is wrapped.
I think you can work the rest. I think there's no major mistake, feel free to correct me.
You understod the probmlem I think but I'm not quite following you Evil_kyo. I only need one kind of h since it's falling from 0 to 2 m. I have been trying to solve this with conservation of energy. I can't see from you equation what the tangential speed v should be, is the equation equal to zero or mgh?
With thanks,
Gunnar
The only kind of h that you need is nothing but Evil_Kyo's [tex]h_1 - h_2[/tex](taking origin at the pulley)
Since your [tex]h_1 = 0[/tex] and [tex]h_2 = -2[/tex],
Your only kind of h = [tex]\0-(-2) = 2[/tex]
Tangential speed cannot be mgh!
As prasanna has noted i haven't selected a origin for the potential energy.
[tex]h_1[/tex] and [tex]h_2[/tex] mean the initial and final position of the falling mass attached to the pulley. You don't know it but you know its difference [tex]h_1-h_2[/tex] that equals the length traveled by the falling mass 2 metres.
Conservation of energy states that the initial energy of the system equals the final energy, then
[tex]mgh_1=\frac{1}{2}(I_1+I_2)\omega^2+\frac{1}{2}mv^2+mgh_2[/tex]
rearranging
[tex]mg(h_1-h_2)=\frac{1}{2}(I_1+I_2)\omega^2+\frac{1}{2}mv^2[/tex]
now we have the equation relating the angular speed [tex]\omega[/tex] of the pulley and the linear speed [tex]v[/tex] of the falling mass.
Imagine the pulley rotates an angle [tex]\omega[/tex] in a unit of time, then the length of string unrolled is equal to the length of arc subtended by this angle [tex]s=\omega r[/tex]. If the pulley rolls [tex]\omega[/tex] in a unit of time the mass falls [tex]\omega r[/tex] in a unit of time, then [tex]\omega r[/tex] is the speed [tex]v[/tex] of the mass.
Using this equation we can simplify
[tex]mg(h_1-h_2)=\frac{1}{2}(I_1+I_2)(\frac{v}{r})^2+\frac{1}{2}mv^2[/tex]
[tex]mg(h_1-h_2)=\frac{1}{2}(\frac{I_1+I_2}{r^2}+m)v^2[/tex]
[tex]v^2=\frac{2mgr^2(h_1-h_2)}{I_1+I_2+mr^2}[/tex]
It's finished if there is no major mistake, i hope this helps you.
It works, of course. Thanks a lot.
I love this place.
  • · Replies 18 ·
