Differential equation for motion in mass-spring system with impulse
The discussion focuses on formulating the differential equation for a mass-spring system subjected to an impulse. The mass (m=1) is attached to a spring with a spring constant (k=2) and a damping constant (c=2). At time t=π, an impulse (p=10) is applied, necessitating the inclusion of a delta function in the governing equation. The resulting non-homogeneous differential equation is expressed as ay'' + by' + cy = g(x), where g(x) represents the impulse function.
  • Understanding of differential equations, specifically second-order linear equations.
  • Familiarity with mass-spring-damper systems in classical mechanics.
  • Knowledge of impulse and its representation in mathematical models.
  • Ability to differentiate between homogeneous and non-homogeneous equations.
  • Study the derivation of the general solution for non-homogeneous differential equations.
  • Learn about the application of the delta function in impulse response analysis.
  • Explore the effects of damping on the behavior of mass-spring systems.
  • Investigate numerical methods for solving differential equations in mechanical systems.
Students studying classical mechanics, engineers working with dynamic systems, and anyone interested in the mathematical modeling of physical systems involving impulses.
zpeters1
I am reviewing for a final and I don't know how an impulse affects the differential equation for motion in this mass-spring system. Can someone please help?
A mass m=1 is attached to a spring with constant k=2 and damping constant c=2. x(0)=0 & x'(0)=0. At the instant t=π, the mass is struck with a hammer, providing an impulse p=10.
Write the differential equation governing the motion of the mass.
Any external force applied to the object like that adds an additional function on the right side. You have a non-homogeneous equation with the impulse (delta) function being the additional function.
Do you know the form of homogenous differential equation?
ay''+by'+cy=0
Now as impulse is also given in your question. It means it is an additional quantity. The question can be solve without this aid.
Then you use your homogenous equation of the form given above.
It implies that any additional quantity adds a function in the homogenous equation and make it a non homogenous equation as,
ay''+by'+cy=g(x)
First you try to write your homogenous equation according to your question.
