Need Help with Writing a Subclass in Java: Am I Doing It Right?
  • Context: Java
  • Thread starter Thread starter courtrigrad
The forum discussion centers on writing a subclass in Java named ManMade that extends the superclass Thing. The user seeks assistance with constructors and instance variables, specifically mentioning issues with the name variable initialization and constructor calls. Key points include the need for proper syntax in variable assignment and constructor invocation, as well as the requirement for a main method for compilation. The discussion highlights the importance of correctly using the super keyword and ensuring all variables are properly initialized.
  • Understanding of Java class inheritance and the extends keyword
  • Familiarity with Java constructors and instance variables
  • Knowledge of Java syntax for variable assignment and method calls
  • Basic understanding of Java compilation requirements, including the main method
  • Review Java class inheritance and the super keyword
  • Learn about Java constructors and their overloading
  • Study Java syntax for variable initialization and method invocation
  • Explore Java compilation processes and the role of the main method
Java developers, software engineers, and students learning object-oriented programming who are looking to deepen their understanding of class inheritance and constructor usage in Java.
courtrigrad
Hello all
I need help in writing a subclass (ManMade) that has 2 constructors and 3 isntance variables. Here is my code so far:
Code:
public class Thing
        private double length;        // instance variables (fields)
        private double height;
        private double width;
        private boolean isPurpleFox;
        private double age;
        private static boolean exists;
        public Thing()
            length = 7;
            height = 8;
            isPurpleFox = false;
            age = 0;
            exists = true;
            width = 10;
        public double getlength()
            return length;
        public void setAge(double a)
            age = a;
        public double getage()
            return age;
        public boolean getexists()
            return exists;
        public void setexists(boolean b)
            exists = b;
        public void Triple(int a)
            a = a*3;
            System.out.println(a);
        public Thing (double l, double w, double h )
            length = l;
            width =  w;
            height = h;
// Subclass of Superclass
// Thing
public class ManMade extends Thing {  // inherits from Thing
    private string name;
    private double volume;
    private double surfarea;
    // no argument constructor
    public ManMade()
        super(0, 0); // call the superclass contructor
        name = ;
    // Constructor
    public ManMade( double l, double, w, double h, char s )
        super( l, w, h); // call the superclass constructor
        setName( "Bob" )
        setVolume( v );
        setSurarea( S );
I am not sure whether i am doing this right.
any help is appreciated
Technology news on Phys.org
When you post code, can you please say what you want to do. What is it that you aren't sure of?? You make a subclass by using the extends keyword, like you've done, so what's the problem? All I can see a problem is with the line
Code:
name = ;
You need to write name = " "; cos otherwise the code won't compile (obviously you won't be able to compile that code on its own, as there's no main(), but you know..).
courtrigrad said:
Hello all
Code:
     public ManMade()
        name = ;
Where is the
Code:
Thing
constructor with two arguments?
  • · Replies 35 ·
