New Reply
find a linearly independent subset F of E
Share Thread
Dec14-11, 09:28 PM   #1
Let U be the subspace of R5 spanned by the vectors
E={(1,1,0,0,1),(1,1,0,1,1),(0,1,1,1,1),(2,1,-1,0,1)}.
Find a linearly independent subset F of E with Span(E)=U
2. Relevant equations
3. The attempt at a solution
I figured out that E is linearly dependent and that the solution set to it is
c1=-t, c2=-t, c3=t, c4=t
I'm not sure how to figure out which vectors are linear combos of the each other??
I'm assuming that once I find the linearly dependent one(s), then the remaining vectors will be linearly independent. Will this be F?
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Dec14-11, 09:36 PM   #2
please please PLEASE help me someone, I have a final on this at 8AM :(
Dec15-11, 12:27 AM   #3
Mentor
Quote by csc2iffy View Post
From your work, the vectors in E are linearly dependent. If you set t = 1, you have -1v1 + (-1)v2 + 1v3 + 1v4 = 0, where the vi vectors are the ones in your set.
This equation can be solved for v4 as a linear combination of the other three, so you can discard v4. If the resulting set is now linearly independent, then that's your answer. If the resulting set is still linearly dependent, keep discarding vectors until you get a set of vectors that is linearly independent.
New Reply
Similar discussions for: find a linearly independent subset F of E
Thread Forum Replies
linearly independent? Calculus & Beyond Homework 12
Linear Algebra (Linearly Independent vs. Linearly Dependent) Calculus & Beyond Homework 10
linearly independent Calculus & Beyond Homework 1
Lin. Alg. - Is the set a linearly independent subset of R^3 Calculus & Beyond Homework 5
subset linearly independent? Introductory Physics Homework 9
