| Thread Closed |
Configuring soundcard in linux Redhat 9 |
Share Thread | Thread Tools |
| Dec9-04, 04:13 AM | #1 |
How can I configure my sound card in Linux Redhat 9? When I use sound configuring tool it says "sound card not detected"
If any one can help me with instructions to follow, it will be of great help? Thanks for the help. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Dec9-04, 07:06 AM | #2 |
Recognitions:
What soundcard are you using?
| Dec10-04, 01:27 AM | #3 |
So, what can I do then? Thanks for the help. |
| Dec10-04, 02:38 PM | #4 |
Most likely this is an integrated sound card. Go to www.intel.com and search for drivers for your particular motherboard; the audio drivers will be there. If they don't have a RH9 driver, you can try other Linux drivers they may have, ie RH Enterprise or SuSE9 drivers.
| Dec10-04, 03:22 PM | #5 |
Recognitions:
I would try a knoppix cd and see if it can detect it correctly. I'm almost positve linux supports that audio card. RH9 is pretty old and may not include this relatively new chipset.
| Dec11-04, 12:08 AM | #6 |
You are right, zefram.
It is a integrated soundcard. I have already tried going to intel site and downloaded the particular driver. But that also could not help. It detected the card but complained that driver is not supported. So, what can be done then? Thanks for the help. |
| Dec11-04, 08:19 AM | #7 |
Recognitions:
Try this driver:
ftp://download.intel.com/design/moth...sa-1.0.1.sh.gz I got it from here: http://support.intel.com/design/moth...z/hz_drive.htm Make sure your motherboard matches the version number at the top of the page. To run the file open up a terminal and type this: gunzip intel8x0-alsa-1.0.1.sh.gz chmod 744 intel8x0-alsa-1.0.1.sh su <enter root password> ./intel8x0-alsa-1.0.1.sh |
| Dec15-04, 03:32 AM | #8 |
Hi dduardo,
thanks for the link. I followed your instruction , but then this is what it asked: Intel Motherboard ADI AC97 Audio Device Driver has been compiled Following are the list of driver that has been load : ALSA Base driver : Not Loaded OSS PCM Module : Not Loaded OSS Mixer Module : Not Loaded OSS Midi Module : Not Loaded Do you wish to continue to configure your audio device? When I said ' Yes' , it complained ' Do you have Alsa Utils installed? ' So, where can I find this? Thanks for the help |
| Dec15-04, 03:35 AM | #9 |
Thanks, dduardo
Even though it complained I could listen the sample sound. I don't know why ALSA Utils are required. Thanks, once again. |
| Dec15-04, 07:23 AM | #10 |
Recognitions:
If you most certainly need alsa for the sound to work properly. I would first suggest getting YUM from here:
http://ftp.freshrpms.net/pub/freshrp...rh.fr.i386.rpm Then from the commandline as root you can do the following: yum update yum install alsa* It will automatically go out to the internet, download any dependences and install the software for you. |
| Dec16-04, 12:32 AM | #11 |
Thanks for the link dduardo
What are these YUM? |
| Dec16-04, 05:31 AM | #12 |
Recognitions:
yum is a program like apt-get (debian) or emerge (gentoo) that installs software for you and automagically resolves dependency problems by downloading and installing any additional packages you need. These tools make installing software in linux easier than in windows. I don't know how long you've been using linux, but there is thing called "dependancy hell" in which the software you want to install requires ten other programs, which themselves require ten other programs and you have to go and download and install the dependencies before you can install the program you want.
| Dec17-04, 01:52 AM | #13 |
dduardo,
Hello!! I am new to Linux and learning to operate it. So, thanks for explaining. I followed your instructions but when I said "yum update" it took long time and the prompt command didnot appear. Does it takes so much time for updating. Do these yum's also satisfy motherboard specifications or the link you had given is sufficient? Thanks again for the help. |
| Dec17-04, 09:08 AM | #14 |
Recognitions:
This site has better instructions:
http://linux.lsu.edu/yum.php You'll actually need to place this file in your /etc folder: http://linux.lsu.edu/yum/redhat/9/yum.conf It basically has a list of all the servers you can download files from. Rerun "yum update" to get the lastest list of file, which can take some time. Yum is independent of which computer you have. If you get this file: http://linux.lsu.edu/yum/redhat/9/yu...5-1.noarch.rpm You'll see that is says noarch or no architecture. This means that it doesn't matter which computer you have, it willl install on anything that has redhat. |
| Dec20-04, 02:59 AM | #15 |
Hi dduardo,
When I did "yum update " After sometime this is what it showed: Gathering header information file(s) from server(s) Server: Red Hat Linux 9 - i386 - freshrpms retrygrab() failed for: http://ayo.freshrpms.net/redhat/9/i3...rs/header.info Executing failover method failover: out of servers to try Error getting file http://ayo.freshrpms.net/redhat/9/i3...rs/header.info [Errno 7] HTTP Error (CannotSendRequest): So what should be done then? Thanks for the help. |
| Dec20-04, 03:08 AM | #16 |
Looks like a network connectivity problem to me. I can download the file just fine. Try again?
| Dec22-04, 12:29 AM | #17 |
You are right, zefram. There is some connectivity problem. I will try again.
Thanks. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Configuring soundcard in linux Redhat 9
| Windows Vista, Linux 32-bit, Linux 64-bit | Computing & Technology | 1 | ||
| Do I need a soundcard? | Computing & Technology | 1 | ||
| Redhat vs. Mandrake (vs. Suse?) | Computing & Technology | 7 | ||
| Configuring band-pass on National MF10 SCF chip | Electrical Engineering | 1 | ||
| mail server on redhat 9.0 | Computing & Technology | 5 | ||
