Interference in Air Wedges exercise
The problem involves calculating the wavelength of light in air using the setup of two glass plates forming an air wedge. The original poster is trying to determine how the dimensions of the glass plates and the separation of dark fringes relate to the wavelength of light.
  • Participants discuss the need to calculate the wavelength of light in air rather than in glass, considering the effects of phase shifts at the interfaces. There is uncertainty about how to incorporate the dimensions of the glass plates into the calculations.
Some participants have offered insights about the relationship between the thickness of the air wedge and the separation of dark fringes. There is ongoing exploration of how to apply the information provided in the problem statement to derive the wavelength.
The original poster notes a lack of guidance in their physics book regarding this type of question, which may affect their understanding of the problem setup and the necessary equations.
Supergabson
I have this question for my physics assignment.
Two plane glass plates 10.0 cm long, touching at one end , are separated at the other end by strip of paper 1.5x10[itex]^{-3}[/itex] mm thick. When the plates are illuminated by monochromatic light, the avreage distance between constructive dark fringes is 0.20 cm calculate the wave length of the light.
I used the equation 2t=[itex]\frac{λ}{2}[/itex] but it gives me the wavelength of light in glass and I am looking for wavelength in air. please help:confused:
My physics book doesn't say how to do this type of question :(
how to solve this question?
The interference occurs as a result of the path in the air wedge so you are correct... you need the λ of the light in air.
One other consideration is that a phase shift of ∏ occurs at the reflection from the air/glass surface.
Just realized !
The question wants you to calculate the wavelength of light !
You have information about the separation of dark fringes, the dimensions of the glass and the separation of the glass plates
What formula should I use that has the dimensions of the glass? I have no idea how the dimensions of the glass can lead me to the right answer
You need the dimension of the glass to get the thickness at distance d from the edge. The interference happens between the wave reflected from the front air wedge-glass interface and the one reflected from the back interface: the blue and green rays in the figure. "t " means the thickness at the spot of a dark strip along the wedge. As the green wave changes phase at the back air-glass interface, destructive interference occurs when 2t n(air) = mλ. The thickness varies with the distance d from the edge, how? For the consecutive dark strips, separated by 0.2 cm,
the order m differs by 1. What is the difference of the thickness between those spots?
ehild
