Thread Closed
Can someone explain why this works?
Share Thread Thread Tools
Dec20-11, 05:38 PM   #1
This sounds very hokey (in a metaphysical way), and I am sorry for that. It isn't, it is a very serious question....
A number of years ago a friend gave me a "healing wand." It is nothing more than hard copper (water) pipe(maybe a foot long?), and a natural quartz crystal "point". But this thing creates heat?
When it was given to me, the friend made me close my eyes and hold my hand out so I couldn't see what she was doing. She swirled this thing over the palm of my hand slowly, about two inches above my hand. I could actually feel this hot spot going around, and I could also feel it "drag", like the spoon indentation when you stir pudding (does that even make sense?). I have done this same trick to several complete non believers, and they were stunned at the amount of heat you can feel.
How a short piece of copper pipe and quartz can create heat is beyond me. I have since played with many of my points in my rock collection, and have found that some naturally give off a tiny amount of heat, while others seem not to. And in the metaphysical world, the copper magnifies this "natural energy."
I have hesitated asking this question here for the longest time because I fear being put in the box of a looney believing metaphysical crap, so please just scientific answers only? Even if it is a guesstimate of how this heat is even possible from just quartz and copper?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Dec20-11, 05:46 PM   #2
Evo
Mentor
Quote by Ms Music View Post
Have you tested the heat of the crystal with an instant read thermometer? Why don't you do that and tell us what temperature it is and also test other objects. Do not hold the copper tube as body heat can be transfered to the pipe from your hand.
Dec20-11, 06:56 PM   #3
Interesting thought, Evo. I always suspected the quartz is actually not creating measurable heat, but somehow you feel heat in the hand. I guess I should not have said it creates heat, but heat can be felt from it. I had wondered if it was caused by some process similar to magnetism, or like the oscillations created in quarts watches that could somehow be detected as heat at a small distance. I don't have an instant read thermometer, but I will get one and see if it detects any temperature difference, or if the quartz is actually warmer than the surrounding objects. I highly doubt that it will, but I will test your idea just to make sure.
Is there any property of either quartz or copper that would create this feeling of heat?
Dec20-11, 07:35 PM   #4
My simple guess would be the following:
Your body is at at temperature of 98.6 degrees F as measured by a thermometer placed in your mouth. Your hand, being an extremity, would be at a somewhat lower temperature perhaps 80 F or 85 F, but that figure is disputable, and it depends where your hands have been. Since all material bodies that have a temperature radiate heat, your body and your hand are also radiating heat through infrared radiation to the surroundings. Your surroundings, or your room if you like, are at a lessor temperature and not necessarily room temperature of the air; but being at a lessor temperature radiate less heat to your body than your body radiates to the surroundings.
Put both your hands up to your face and your face will begin to feel warmer. This is due to the fact that now your face is radiating to your hands and your hands are radiating to your face. Your face is receiving radiation from a warmer object than when it is uncovered.
For the crystal on a stick, I propose that what is happening is that the cystal is reflecting the infrared radiation from your hand back to your hand and you feel a hot spot. The radiation would be in the far infrared and the cyrstal itself would "feel" cold to the touch.
Other PF'rs may agree or call me out on the technicalities, is but I do believe that what is happening is along this description.
Dec20-11, 08:21 PM   #5
Evo
Mentor
If there is no heat to be measured, then is it really heat or just imagining heat? If you have the money, get one of those cool infrared surface thermometers that you point at the object, that way you could also point it at your hand while waving the wand over it to see if it's really causing your hand to heat up. But those start around $40-$50 for a cheap one at Walmart.
I have a regular instant read that you need to touch the tip to the object, but it was less than $10.
Dec20-11, 08:49 PM   #6
Recognitions:
Gold Membership Gold Member
I don't see how this would in any way explain your observation, but there are atypical things about copper and quartz.
1) Copper is a good conductor of heat and electricity. (I assume you knew that).
2) Quartz is piezoelectric: apply pressure, charge is generated. Apply electric field, mechanical stress is produced; apply vibration and you get varying electric field; apply varying electric field and crystal will vibrate.
3) Quarts is triboluminescent. Hit or scraped it will produce faint flashes of light. (To see this, you need pitch darkness with full adaptation of your eye to the dark).
But, I really don't see how any of these account for your observation.
Dec21-11, 01:39 AM   #7
Quote by PAllen View Post
2) Quartz is piezoelectric: apply pressure, charge is generated. .
Of decisive importance for the piezoelectric effect is the change of polarization P when applying a mechanical stress. This might either be caused by a re-configuration of the dipole-inducing surrounding or by re-orientation of molecular dipole moments under the influence of the external stress. Piezoelectricity may then manifest in a variation of the polarization strength, its direction or both, with the details depending on 1. the orientation of P within the crystal, 2. crystal symmetry and 3. the applied mechanical stress. The change in P appears as a variation of surface charge density upon the crystal faces, i.e. as a variation of the electrical field extending between the faces, since the units of surface charge density and polarization are the same, [C/m2] = [Cm/m3]. However, piezoelectricity is not caused by a change in charge density on the surface, but by dipole density in the bulk. For example, a 1 cm3 cube of quartz with 2 kN (500 lbf) of correctly applied force can produce a voltage of 12500 V.[7]
http://en.wikipedia.org/wiki/Piezoelectricity
If the crystal were mounted such that two faces are squeezed it ought to exhibit a definite electric field with one face being positive and the other negative. Proximity to the hand would induce an equal dipole (opposite in signs) in the hand, just based on the fact that the proximity of any field to an insulator will attract charges of the opposite sign to the area of the insulator exposed to the field.
This excess of charge in the skin might have the same effect on heat-sensing nerve endings that heat does: it may trigger them to fire, sending the erroneous message of heat sensation to the brain.
It could be strong charge of either polarity would do this, or it could be the skin has to experience a relatively fast shift from one polarity to the other.
We know from the phenomenon of dielectric heating that materials can be physically heated just by rapidly alternating an electric field around them.
http://en.wikipedia.org/wiki/Dielectric_heating
This wouldn't be the same: there would be no objective heat produced, but the change in field might be enough to depolarize the nerve endings responsible for heat sensation.
Thermoreceptors have been classically described as having 'free' non-specialised endings; the mechanism of activation in response to temperature changes is not completely understood.
http://en.wikipedia.org/wiki/Thermoreceptor
Dec21-11, 09:41 AM   #8
Recognitions:
Quote by zoobyshoe View Post
Interesting ideas. Maybe there is a real effect here.
Dec21-11, 10:26 AM   #9
In principle there could indeed be a non-psychological, objective effect. The wiki article on thermoreceptors mentions how cold receptors can be activated chemically to perceive cold in the absence of any authentic drop in temperature:
Since the TRPM8 is expressed in neurons whose physiological role is to signal cooling, menthol applied to various bodily surfaces evokes a sensation of cooling. The feeling of freshness associated with the activation of cold receptors by menthol, particularly those in facial areas with axons in the trigeminal (V) nerve, accounts for its use in numerous toiletries including toothpaste, shaving lotions, facial creams and the like
So, on the principle that cold receptors can be made to fire by things that aren't actually cold, so too, heat receptors might be made to fire by things that aren't authentically hot. An electric field is a perfectly good suspect for that. Someone ought to be able to measure the voltage across a squeezed crystal with a common VOM, and someone might likewise mount two metal plates on the end of a stick, charge them like a capacitor, and wave them over someone's hand to see if the same sensation of heat is created. It's all testable.
Dec21-11, 12:01 PM   #10
Recognitions:
Create a roughly identical wand made of small PVC pipe and put a chunk of granite on the end.
If you trust your own perceptions, then have your friend randomly select from the two wands and wave them over your hand. Do your best not to cheat, and keep your eyes closed.
If you can tell the difference between the two wands, then you can continue your investigation. If you can't, then the effect is psychosomatic (or the PVC/granite combo is equally effective).
I propose this solution because your friend is less likely to refuse. Trust me, when you try to measure woo-woo, the practitioners hate it.
Dec21-11, 02:45 PM   #11
Quote by FlexGunship View Post
If you wave anything at all over someone's hand when they have their eyes closed and they feel heat, that, itself, would have to be explained, since they can't see what you're doing.
Dec21-11, 06:47 PM   #12
And THAT is exactly the reason why I even have this novelty item in my house. Not only could I feel the heat, but the circular motion and the speed with my eyes closed. All from about two inches away. It was so strange I had to accept the gift just to figure it out.
Zooby, thanks for the links. I haven't had any free time today to read them, but from the short descriptions you and PAllen provided, they sound like they will provide some good meat to sink my teeth into. It sounds like I won't get my answers, I fear it will all be pure speculation. But oh well. Then I will see what I can do to prove something, at least in my own mind. I will in the very least try Evo and Flex's tests, hopefully others.
Tomorrow will be hectic, I may not be back online until next Tuesday, but I will definitely try to read up on those 3 links, and ask questions when I come back.
Thank you everyone so far for the ideas!
Happy Holidays
Dec21-11, 08:57 PM   #13
Evo
Mentor
Happy Holidays
Let us know what you find! Happy Holidays!!
Dec22-11, 08:33 AM   #14
Recognitions:
If I tell you to close your eyes and explain that I'm going to bring a match as close to your hand as possible, it's likely that you'll experience the sensation of heat just at the mere sound of a match lighting regardless of whether or not I ever bring it near your hand.
Psychosomatic effects aren't fake.
Dec23-11, 05:54 PM   #15
Yes, but if I tell you to close your eyes, put out your hand, and ask you what you feel without suggesting any particular sensation, why should you feel a moving heat spot?
Dec26-11, 11:17 AM   #16
Hi, I would like to attempt the pros and cons of the three links posted earlier, one by one, starting off with this link and comments on Piezoelectricity:
And from PAllen's post:
From what I was able to understand from the wiki article, the piezoelectricity is caused from an applied stress. As this crystal is literally just hot glued to the copper, does that make this effect not possible in this situation? I just want to make sure I am not throwing the baby out with the bathwater, just because I don't fully understand the concept.
Dec30-11, 08:25 AM   #17
Yes, the crystal has to have pressure on it to produce a field. It has to be stressed. If it's not under any stress it ought to be electrically neutral.
I was assuming it was inserted into the pipe and held in place by friction. If it is not, then it would be experiencing only a small stress from being held at some angle not perfectly along the normal of gravity, and a larger stress when being waved around, but neither of these would be anywhere near as large as that from the pipe squeezing the crystal.
Unfortunately, you can't throw the bathwater out yet, at all. The effect I proposed is hypothetical and can't be ruled out since there are no known parameters. What would the threshold voltage be to cause a heat receptor to fire? Would too much voltage somehow obviate the effect?
I think the first step would be to rigorously prove there is such an effect. The person should be told nothing, be well blindfolded, and be tested with several different materials: a plain wooden stick, a plastic rod, a steel rod, etc. Additionally, the person doing the waving of the object over the hand should be a volunteer naive of the sensation the other is supposed to feel, least they cue them somehow about what they're supposed to experience.
Flexgunship is right that direct suggestion can easily produce sensation, as this Derren Brown video proves:
As we can see at the beginning, these strippers are hypersensitive to the notion of being touched to begin with, and, it can be assumed, easily convinced they've been touched when they haven't. He directly tells them he is going to touch them, even though he never does, thus creating that expectation. (I assume they are hearing him move his arm,or, that he's moving enough air when he does it that they can feel that, and that is what's triggering the sensation they expect.)
In testing the crystal, all such priming and suggestion, however subtle, has to be eliminated, before everyone will be convinced there is an effect to be studied.
Thread Closed
Thread Tools
Similar Threads for: Can someone explain why this works?
Thread Forum Replies
Can someone please explain to me how this works? General Math 4
Can someone explain to me how a minor degree works? Career Guidance 2
video inside: could someone explain how this works? General Discussion 3
how can you explain how a balance works vectorially? General Physics 5
Can someone explain how attraction works? High Energy, Nuclear, Particle Physics 13
