Why Is a Distant Galaxy Blue Despite Redshift?
The discussion revolves around the phenomenon of redshift in distant galaxies, particularly addressing the observation of a distant galaxy appearing blue despite the expectation of redshift. Participants explore the implications of gravitational lensing and the factors influencing the color of galaxies.
  • One participant questions how a distant galaxy can appear blue when it is generally understood that more distant galaxies are redshifted.
  • Another participant clarifies that redshift refers to an increase in wavelength and does not necessarily mean that light appears redder to the observer.
  • A participant suggests that gravitational lensing could cause a distant galaxy to appear blue-shifted due to the distortion of light.
  • It is noted that the color of a galaxy is influenced by the types of stars it contains, with hotter stars contributing to a bluer appearance.
  • One participant proposes that the blue light observed may be a result of ultraviolet radiation becoming visible due to redshift effects.
Participants express differing views on the implications of redshift and gravitational lensing, with no consensus reached on how these phenomena interact to affect the observed color of distant galaxies.
Participants mention various factors that could influence the observed color of galaxies, including the presence of hot stars and the effects of gravitational lensing, but do not resolve the complexities involved.
Last_Exile
Hi,
The recent Astronomy Picture of the Day:
http://apod.nasa.gov/apod/ap111221.html
Has the following caption:
...the gravity of a luminous red galaxy (LRG) has gravitationally distorted the light from a much more distant blue galaxy.
I was under the impression that the more distant a galaxy is then the more red-shifted it becomes. So my question is how can the more distant galaxy be blue?
Thanks in advance.
Astronomy news on Phys.org
Last_Exile said:
Hi,
Thanks in advance.
Hello,
You appear to have a misconception with regards to redshift. Redshift does not mean becomes redder, it corresponds to a longer wavelength - moving to the "red" end of the spectrum so through the visible spectrum to eventually x rays, gamma rays.
Please see the following link for clarification:
http://en.wikipedia.org/wiki/Redshift
Extract: "In physics (especially astrophysics), redshift happens when light seen coming from an object is proportionally increased in wavelength, or shifted to the red end of the spectrum. More generally, where an observer detects electromagnetic radiation outside the visible spectrum, "redder" amounts to a technical shorthand for "increase in electromagnetic wavelength" — which also implies lower frequency and photon energy in accord with, respectively, the wave and quantum theories of light."
Hmmm...
Wouldn't that still mean that the light appears redder to the observer?
http://www.setterfield.org/000docs/Redshift.htm
In the simplest terms, 'redshift' is a term used to describe the fact that the light seen from distant galaxies shows up a little differently than it does here on earth. Each element has a 'fingerprint' in light. This is how we know which elements are in which stars. There is a certain pattern of lines associated with each element which identifies it. However, as we get further and further out in space, these identifying lines, while keeping the same identifying patterns for each element, appear shifted somewhat to the red end of the spectrum -- thus causing the light to appear redder than it would be here on earth.
My emphasis.
Last_Exile said:
Hmmm...
My guess is one of the side effects of gravitational lensing would be a change in wavelength. Thus the further galaxy (the blue one that's now an Einstein Ring) would appear blue-shifted to us simply because of the distortion caused by the gravitational lensing.
The "color" of a galaxy relies on more than just its Doppler shift. A galaxy of mostly hot stars will be bluer than one with cooler stars or one that is dusty. It takes quite a sever doppler shift to cause a visible reddening of a galaxy. The light at the blue end of the spectrum that is shifted to the red is replaced by ultraviolet that shifts from being invisible to being blue.
Thanks Janus, that does seem to make sense.
It would imply that the lensed galaxy, now appearing blue (and much further away) consisted of extremely hot stars whose ultra-violet radiation is now visible to us.
My faith in science is restored!
  • · Replies 23 ·
  • · Replies 18 ·
  • · Replies 57 ·
17K
  • · Replies 30 ·
10K
