Shining a Torch at the Moon: Does Light Travel Faster than c?
  • Context: Graduate
  • Thread starter Thread starter Bruninho
    Light Moon Travel
The discussion revolves around the question of whether the spot of light created by a torch shining on the moon can move faster than the speed of light (c) when the torch is swung across the lunar surface. Participants explore the implications of this scenario on the nature of light, information transfer, and the behavior of photons.
  • Some participants assert that the spot of light can move faster than c, but clarify that this does not mean any physical object is traveling at that speed.
  • One participant emphasizes that the spot is not a physical entity but rather a result of different photons hitting different locations on the moon's surface.
  • Another participant raises the concern that if the spot can move faster than c, it could imply that information could also travel faster than c, questioning the implications of this idea.
  • There is a discussion about a hypothetical scenario where a light source is turned to shine on objects 10 light years apart, which leads to the conclusion that while the spot may appear to move quickly, it does not account for the travel time of the photons.
  • Some participants agree that while the spot can move faster than c, no information can be transmitted between two points on the moon faster than c, as communication relies on the speed of light from the source to the moon.
Participants express differing views on whether the spot of light can be considered to move faster than c and the implications of this for information transfer. There is no consensus on the interpretation of these phenomena.
The discussion includes assumptions about the nature of light and the definition of information transfer, which may not be universally agreed upon. The implications of the travel time of photons are also noted but not resolved.
Bruninho
If I shine a torch at the moon the light will after a time be seen on the surface. If I then swing the torch so as to move across the moon does the spot of light on the surface travel faster than c?
Sure. But realize that this does not entail any physical object traveling at that speed.
yes!
photons can travel faster than c, I am gana post a new thread on it right not.
Gamish, the spot is not a thing to move. The spot is just individual photons hitting the moon at a certain place. When you "move the spot" it is just different photons hitting the moon somewhere else. Nothing is moving except the source of the photons.
You are just talking about two different photons hitting two different places very close to each other in time. Nothing moved.
I was thinking a bit more about this, and can even the spot move faster than C? Wouldn't that imply that information can travel faster than C?
Think about a more extreme example. You shine a light 10 light years away in one direction, then flip around to shine on an object 10 light years away in the opposite direction. By the original example the "spot" has moved 20 lightyears in a very short time, but this neglects the travel time for the photons from the flashlight to the object.
I would assume there would be a similar issue on the moon. Or am I misunderstanding something?
Yes, the spot can move faster than c. But as the spot moves from one side of the moon to the other, no information travels between those two points. (Astronauts on opposite sides of the moon cannot use the spot to communicate; the only potential for information transfer is between the light source and the moon, and that information would of course travel at speed c.)
The travel time only introduces a delay in the time it takes the "spot" to reach the object; but that delay is a constant 10 years, so it doesn't affect the "sweep rate" of the spot.
As far as I know,there's no way you can use that spot to send a message from point A to point B on the moon, at a speed faster than c. If you've nevertheless figured out a way to do it, or read about a way to do it, please tell us about it.
  • · Replies 51 ·
  • · Replies 53 ·
  • · Replies 19 ·
