Electron capture vs internal conversion electrons vs auger electrons
Internal conversion electrons, electron capture, and Auger electrons are distinct processes in nuclear and atomic physics. Internal conversion involves the nucleus de-exciting by ejecting an atomic electron, typically from the K shell, while electron capture occurs when a proton captures a K shell electron, transforming into a neutron and emitting a neutrino. Auger electrons result from X-ray emissions during atomic electron transitions, potentially linked to electron capture events. Understanding these differences is crucial for applications in nuclear physics and spectroscopy.
  • Knowledge of nuclear decay processes
  • Understanding of atomic electron shells and transitions
  • Familiarity with X-ray emission mechanisms
  • Basic concepts of particle interactions in physics
  • Research "Nuclear decay processes and their applications"
  • Study "Atomic electron transitions and X-ray production"
  • Explore "The role of Auger electrons in spectroscopy"
  • Investigate "Internal conversion in nuclear reactions"
Physicists, nuclear engineers, and students studying atomic and nuclear interactions will benefit from this discussion, particularly those focusing on decay processes and electron interactions.
lavster
what is the differece between internal conversion electrons, electron capture and auger electons? i don't understand. The name suggests electron capture and internal conversion electrons are the same thing... but then when i look it up internal conversion electrons seem to be the same as auger electrons... but I am assuming they are three didferent things?
thanks
With Internal Conversion "instead of emitting a gamma-ray, the nucleus de-excites by knocking out one of the atomic electrons with kinetic energy equal to the decay energy. It is usually the K shell electron that is internally converted because it has the greatest wave function overlap with the nucleus. The hole that is left behind will be repopulated by an electron from a higher atomic shell, usually the L shell, and this L to K transition is accompanied by an X-ray."
Ref: http://www.pma.caltech.edu/~ph77/labs/tabis.pdf (see discussion under 137Cs)
In Electron Capture, a proton in the nucleus actually captures an atomic electron, usually a K electron, whereby the proton is transformed into a neutron, and a neutrino is emitted. The atomic number decreases by 1.
Auger electrons are actually caused by X-rays, i.e., photons from atomic electron transitions. It's possible that Auger electrons arise from the X-ray associated with Electron Capture.
http://www.microscopy.ethz.ch/auger.htm
http://www.prenhall.com/settle/chapters/ch42.pdf
FYI - Internal conversion electrons and supernova light curves
http://arxiv.org/abs/1012.4647
