Work & Friction: Solve for Force, Work, & Speed
  • Thread starter Thread starter lostinthespiral
    Friction Work
The discussion revolves around a physics problem involving work, friction, and motion. The scenario describes a block being dragged across a rough surface, with specific parameters such as mass, applied force, angle, displacement, and coefficient of friction provided.
  • Mixed
  • Participants explore the relationship between the applied force, friction, and work done on the block. There are attempts to apply the work-energy theorem and questions about how to calculate the work done by friction and the final speed of the block.
Some participants have provided calculations for the work done by the applied force and are seeking clarification on the work done by friction. There is an indication of reviewing calculations and exploring different aspects of the problem, such as time and velocity.
Participants are grappling with the integration of friction into their understanding of work and motion, and there are repeated requests for help with specific calculations. The original poster expresses confusion about combining these concepts effectively.
lostinthespiral
I am having real trouble understanding friction force. Work I understand. I just don't know how to put them together. Some help would be highly appreciated.
A 16.1 kg block is dragged over a rough, horizontal surface by a constant force of 118 N acting at an angle of 25 degrees above the horizontal. The block is displaced 78.6 m, and the coeficient of kinetic friction is 0.228. The acceleration of gravity is 9.8 m/s2.
a.) Find the work done by the 118 N force. Answer in units of J. - I've already found this to be 8405.82346 J
b.) Find the work done by the force of friction. Answer in units of J.
c.) If the block was originally at rest, determine its final speed. Answer in units of m/s2.
Net work done on object = (horizontal component of 118 - frictional force) * distance
Net work done on object = change in kinetic energy (work-energy theorem)
a.) Find the work done by the force of friction. Answer in units of J. - I've already found this to be 8405.82346 J
Please,review both the text (the first question and the second are identical),and the result to your first calculation.
For the third,compute the time in which the body moves along those 78,6 m and from there,u can find the velocity.
Alright. Fixed.
  • · Replies 58 ·
