Palindrom
- 263
When I'm in a dimension higher than 1, do I need to integrate over all space (V) or only the x axis?
Thanks in advance.
Thanks in advance.
The calculation of the expectation value in quantum mechanics (QM) requires integration over all dimensions in which the physical quantity exists. For a wavefunction \(\psi(x,y,z)\), the expectation value \(\langle \hat{x} \rangle\) is computed using the formula \(\langle \hat{x} \rangle = \int\int\int_{R^{3}} \psi^{*}(x,y,z) x \psi(x,y,z) \, dx \, dy \, dz\). If the quantity X is scalar and only exists along the x-axis, integration is limited to that axis. However, for vector quantities existing in three dimensions, integration must encompass all axes to ensure accurate results.
PREREQUISITESStudents and professionals in physics, particularly those specializing in quantum mechanics, as well as researchers interested in the mathematical aspects of quantum systems and their measurements.
Palindrom said:When I'm in a dimension higher than 1, do I need to integrate over all space (V) or only the x axis?
Thanks in advance.
