Domain and range of composite function
The problem involves determining the domain and range of the composite function f∘g, where f(x) = 3e^(2x) and g(x) = ln(4x). The functions have specified domains, and the discussion centers around the implications of these domains on the composite function.
  • Participants explore the relationship between the domains and ranges of the functions f and g, questioning how the range of g affects the domain of f∘g. There are discussions about the limits of the functions and the implications for the composite function's domain and range.
The discussion is ongoing, with participants providing insights and corrections regarding the domains and ranges. Some participants have offered clarifications about the arithmetic involved in the composite function, while others have raised questions about the definitions and assumptions related to the functions.
There is some confusion regarding the domains of the functions, particularly whether 0 is included in the domain of f. Participants are also addressing the implications of these domains on the composite function.
Gwyddel
The function f has domain (-∞, ∞) and is defined by f(x) = 3e2x.
The function g has domain (0, ∞) and is defined by g(x) = ln 4x.
(a) Write down the domain and range of f∘g.
(b) Solve the equation (f∘g)(x) = 12
2. The attempt at a solution
(a)
Is it correct to think that the domain of f∘g will be all those x in the domain of g which produce g(x) in the domain of f? The domain of f is ℝ, so there's no restrictions on the g(x), so I think the domain of f∘g is the same as the domain of g, which is (0, ∞).
Taking the limit of 3e2x as x→-∞ gives me 0, and x→∞ gives ∞. I got that the range of f is (0, ∞). I, uh, think the range of g is (-∞, ∞).
I notice that the range of g and the domain of f are the same: (-∞, ∞). I therefore conclude that the range of f∘g will be the same as the range of f.
Domain of f∘g: (0, ∞)
Range of f∘g: (0, ∞)
(b)
f∘g(x) = 3e2ln4x
= 3eln(4x)2
= 3ln16x2
= 6ln16x​
(6ln16x)/6 = 12/6
ln16x = 2
16x = e2
x = e2/16 = 0.4618... ≈ 0.5
I really don't know if any of this is right, and these questions always make me scratch my head. Especially any question on the domain and range of a composite function.
first look at your functions and determine the ranges too.
the range of one function will be the possible domain of values for the other.
so say the domain of the inner function is -1 to 1 and the range of the inner function is -10 to 10 but the domain of the outer function 0 to 100 then what is the actual domain of values for the composite?
I think it would be 0 to 1 right because the -1 to 0 is clipped off by the limit of 0 to 100 constraint of the outer.
does that help without giving away the answer?
(a)
(b)
f∘g(x) = 3e2ln4x
= 3eln(4x)2
= 3ln16x2
What happened to the "e"? ex and ln(x) are inverse functions so eln((4x)^2)= (4x)2= 16x2.
= 6ln16x​
(6ln16x)/6 = 12/6
ln16x = 2
16x = e2
Oh! That was very silly of me.
3eln(4x)2 = 3(16x2) = 48x2
48x2 = 12
x2 = 12/48 = 1/2
x = 1/√2, x = -1/√2
Exclude x = -1/√2 because it is outside the domain of fg?
48x2 = 12
x2 = 12/48 = 1/2
x = 1/√2, x = -1/√2
Checked the bolded above. Also, I assume you mean f ° g, not fg. The former is a function composition, and the latter is a multiplication of functions. They are not the same thing.
Ah, okay, so correcting my silly arithmetic error.
x2 = 12/48 = 1/4
x = plusorminus sqrt(1/4) = 1/ (plusorminus sqrt(4))
x= 1/2, -1/2 (which is not accepted because it is not on the interval (0, ∞), the domain of f ° g).
The domain of g is (0, oo), and the domain of f is (-oo, 0) U (0, oo).
The domain of 2ln(4x) is (0, oo), as opposed to the domain of ln[(4x)^2],
which is (-oo, 0) U (0, oo).
Then the domain of the composite function, f(g(x)) = 3e^{2ln(4x)}, is (0, oo).
The graph of the composite function is the right half portion of a parabola.
Why is 0 not in the domain of 3exp(2x) ?
0 is in the domain of f. checkitagain is wrong.
Edit
f is (-oo, oo). This is corrected now.
Thank you all for your valuable help!
  • · Replies 22 ·
  • · Replies 23 ·
