Prove If x^2 is irrational then x is irrational
  • Thread starter Thread starter basil32
    Irrational
The discussion revolves around the proof of the statement "If x^2 is irrational, then x is irrational." Participants explore various approaches to establish this relationship, particularly focusing on proof by contradiction and the properties of rational numbers.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Some participants suggest a proof by contradiction, starting with the assumption that x is rational and exploring the implications for x^2. Others question the necessity of proving that p^2/q^2 is in reduced form if it is already established as rational.
The discussion is active, with participants providing hints and exploring different lines of reasoning. Some guidance has been offered regarding the properties of rational numbers and the implications of coprimality, although no consensus has been reached on all points raised.
Participants express a need for clarification on certain mathematical properties, such as the irreducibility of fractions and the implications of coprime integers in the context of this proof.
basil32
Prove If x^2 is irrational then x is irrational. I can find for example π^2 which is irrational and then π is irrational but I don't know how to approach the proof. Any hint?
Try a proof by contradiction. Let's say you have such a rational [itex]x[/itex] where [itex]x^2[/itex] is irrational. Then let [itex]x = \frac{p}{q}[/itex] where p and q are coprime integers (meaning it's a reduced fraction). Now see what form [itex]x^2[/itex] takes. Can you arrive at a contradiction considering that this was supposed to be irrational by the first assumption?
ok. [itex]x^{2}[/itex] = [itex]\frac{p^{2}}{q^{2}}[/itex]. Now [itex]q^{2}x^{2} = p^{2} \Rightarrow x^{2} \mid p^{2} \Rightarrow x \mid p[/itex] but I can't arrive at [itex]x \mid q[/itex] for the contradiction (when I replace p =xk in the [itex]q^{2}x^{2} = (xk)^{2}[/itex] the x^{2} on both side cancel)
Wouldn't it suffice to observe that [itex]\frac{p^2}{q^2}[/itex] is a reduced rational number since p and q are coprime? Which would imply that [itex]x^2[/itex] is rational as well, which contradicts the original assumption of the irrationality of [itex]x^2[/itex].
In other words, the negation of the proposition [itex]x^2 \notin \mathbb{Q} \Rightarrow x \notin \mathbb{Q}[/itex] leads to a contradiction. Hence the proposition is true.
yeah, the observation make sense but I need a lemma which proves that [itex]\frac{p^2}{q^2}[/itex] is reduced form whenever [itex]\frac{p}{q}[/itex] is reduced. How do you do that?
I would've thought that bit's obvious, and would've stated it without proof. If you want to see it more clearly, perhaps express it as [itex]\frac{(p)(p)}{(q)(q)}[/itex]. Neither of the numerator's two factors has any factors in common with either of the denominator's factors (since p and q are coprime by definition), so the fraction is irreducible (nothing to cancel out).
The only thing I can think of more fundamental than that would be to fully prime-factorise [itex]p^2[/itex] and [itex]q^2[/itex], but this just leads to a more messy yet no more convincing argument.
Why do you need to show [itex]\frac{p^2}{q^2}[/itex] is in reduced form? It's rational even if it's not in reduced form, isn't it?
Why bother? We know [itex]p^2 \mbox{ and } q^2[/itex] are integers, so [itex]p^2/q^2[/itex] is a ratio of integers, hence a rational number. Who cares if they are coprime?
RGV
Thanks everybody!
  • · Replies 30 ·
  • · Replies 21 ·
