Universal Gravitation - Satellites
The discussion revolves around calculating the ratio of the speeds of a satellite at perigee and apogee, using parameters from the Explorer VIII satellite's orbit. The subject area includes concepts from orbital mechanics and gravitational physics.
  • Participants discuss the application of conservation of angular momentum and various equations related to orbital motion. There are attempts to derive the speed ratio using given parameters, while some participants question the need to adjust for the Earth's radius in the calculations.
The conversation has progressed with participants sharing their attempts and corrections. Guidance has been provided regarding the necessity of including the Earth's radius in the calculations, and there is an acknowledgment of the original poster's efforts to engage with the problem.
The original poster clarifies that this problem is part of their exam preparation, not a standard homework assignment, which may influence the nature of the discussion.
BbyBlue24
The Explorer VIII satellite, placed into orbit November 3, 1960, to investigate the ionosphere, had the following orbit parameters: perigee, 459 km; apogee, 2289 km (both distances above the Earth's surface); period, 112.7 min. Find the ratio vp/va of the speed at perigee to that at apogee.
Welcome to Physicsforums, BbyBlue.
First off, questions like this should be submitted to the homework help section.
Second, before you can expect an answer, you should at least post what you have tried to get an answer.
It doesn't benefit you to have someone do your homework for you.
FYI: This isn't a homework problem, I am doing random problems throughout the book to prepare for an exam tomorrow.
I have played around with equations of conservation of angular momentum and equations such as v=(2πr)/T and v=√(GMe/r)=√(GMe/Re+h). I tried using Vp=(Ra/Rp)Va, but I have gotten nowhere. Thanks!
Well, by using conservation of angular momentum for the satellite
[tex]r_{perigee} v_{perigee} = r_{apogee} v_{apogee}[/tex]
we rearrange this to:
[tex]\frac{v_{perigee}}{v_{apogee}} = \frac{r_{apogee}}{r_{perigee}}[/tex]
you don't need the period.
I have; Vp/Va = Ra/Rp = 2289/459 = 4.99 km
The problem states distances above the surface, you need to add the Earth radius to each of those radius.
I got it, thanks! I think that's all I have tonight, thank you very much!
good luck on your test.
