Shear valve Design. Wall thickness at break point.
The discussion centers on calculating the wall thickness and outside diameter of a shear valve designed to break under a specified bending moment. The user employs the modulus of rigidity and bending stress equations to derive the necessary dimensions for a stainless steel 304 pipe. Key variables include a yield stress of 30,000 psi, an inner diameter of 1 inch, and a bending moment of 500 lb-feet. The calculations yield an outside diameter of approximately 2.446 inches, which the user finds unsatisfactory, indicating potential errors in the equations used.
  • Understanding of shear force and bending moment concepts
  • Familiarity with material properties, specifically for stainless steel 304
  • Knowledge of stress and strain calculations in mechanical engineering
  • Proficiency in using equations for inertia and cross-sectional area
  • Research the relationship between bending stress and moment of inertia in pipe design
  • Learn about the impact of wall thickness on shear strength in piping systems
  • Explore advanced material mechanics, focusing on stainless steel properties
  • Investigate alternative methods for calculating outside diameter in shear applications
Mechanical engineers, structural designers, and anyone involved in the design and analysis of shear valves and piping systems under load conditions.
cdf0080
Hi.
Situation: A pipe with a cut out so it will break when a shear force is exerted at the top of the pipe. The break point is at the cut out and the the force is impact in lbs.
What is the wall thickness(or cross sectional area) at the cut out point?
I know i may be missing variables..
Thank you for reading
I've decided to try it without knowing if it'll work. I decided to use the modulus of rigidity which is in force per area. S=F/A I find the area and say its my cross sectional area. I have a given force, pipe inner radius, and want to find the cross sectional area of the break point. I used this equation A=pi(r+w.t.)^2-pi(r)^2 which can be arrange for wall thickness w.t.=sqroot(A*pi). I keep getting a very low wall thickness(.013 in). Is this calculation right?
** re written **
FBD (probably useless)
Pipe lengthwise cross section
> | | < <-shear point, distance tip of cuts is the outer diameter (D_o)
Problem
A shear pipe is is intended to break while going under 400-600 lb-feet bending moment.
What is the outside diameter of the shear point to break under this load?
Variables
Stainless steel 304
Modulus of Rigidity(G)= 11e3 ksi
Inner Diameter of pipe (D_i) = 1 in
yield stress of 304 SS (σ_y) = 30,000 psi
let Moment (M) = 500 lb-feet = 6000 lb-in
Inertia(I) = ?
Outside diameter at shear section(D_o)
Formula
Bending normal stress = σ_y= (M*(D_o/2))/I
Inertia of pipe = I=(pi/64)(D_o^4 - D_i^4)
Solve Attempt
plugged in for I
I = (pi/64)(D_o^4) - (pi/64)
rearrange σ_y
D_o = (2*σ_y*I)/M
D_o = (2*(30000psi)*((pi/64)(D_o^4)-(pi/64)))/(6000 lb-in)
rearranged and solved
0= (10*pi/64)(D_o^4) - D_o - (10*pi/64)
solve for D_o
equation solver
D_o= 2.44601217,-0.4088289
didn't show but used ultimate strength instead of yield and got 25 and 0. way worse
I'm looking for a number in between 1 and 1.5 in.
I thought this calculation was the real deal.
A mistake or bad equations?
Is there an equation to figure out the outside diameter?
  • · Replies 27 ·
