Where Does a Solid State Relay Draw Power From?
Solid State Relays (SSRs) operate by using a small input signal to control a larger output voltage, drawing the necessary power from an external power supply. Unlike electro-mechanical relays that utilize an electromagnet, SSRs achieve this without moving parts, relying on semiconductor devices. When selecting relays, it is crucial to understand that they require a separate power source for the output circuit, which is often not specified by manufacturers. This distinction is essential for proper relay application and integration in electrical systems.
  • Understanding of Solid State Relay (SSR) functionality
  • Basic knowledge of electrical circuits and power supplies
  • Familiarity with electro-mechanical relay operation
  • Awareness of semiconductor devices used in SSRs
  • Research the specifications and applications of Solid State Relays
  • Learn about the differences between electro-mechanical relays and Solid State Relays
  • Explore power supply requirements for various relay types
  • Investigate the role of semiconductor technology in relay design
Electrical engineers, hobbyists in electronics, and anyone involved in designing or implementing relay-based control systems will benefit from this discussion.
booxcar
Hello,
I am not an electrical engineer but I do have a slight background in some electrical engineering concepts. My question is a general one about relays (more specifically solid state relays but I don't think that really changes my question). I understand that a relay gets a small input signal which is used to control the output voltage of the relay. My question is, where does the relay draw the extra power from? All relays must need some external power supply in order to output power that is much greater than the input signal correct? Maybe I am not understanding things about relays because when I am shopping for them, it seems as though no brands suggest a power supply or anything to provide the extra power for the relay output. Any information would be awesome!
Thanks,
Boox
A relay is a switch rather than an 'output voltage'.
Electro-mechanical relays consist of an electromagnet (a coil) which operates a switch when it is energised. The switch can be used to control a separate electrical circuit with its own power supply.
Solid state relays do much the same job but do not use an electro-magnet.
A 'reed relay' is a small switch sometimes operated by a small permanent magnet brough close to the switch.
  • · Replies 31 ·
  • · Replies 25 ·
