Evaluating 12 C 2: How to Simplify Without a Calculator
  • Context: High School
  • Thread starter Thread starter qwexor
    Factorial
The discussion revolves around evaluating the combinatorial expression 12 C 2 without the use of a calculator. Participants explore methods for simplification and delve into the properties of binomial coefficients.
  • One participant suggests simplifying 12 C 2 using the factorial formula 12! / (10!2!) and asks for easier methods.
  • Another participant recommends computing it step-by-step, emphasizing cancellation of terms to arrive at the result of 66.
  • Further contributions reiterate the cancellation process, confirming that 12 C 2 simplifies to 66 through the same method.
  • One participant poses a question regarding why nCr yields a positive integer when n > r, prompting a discussion on the properties of binomial coefficients.
  • Responses to the question reference the identity (n+1)Cr = nCr + nC(r-1) and the combinatorial interpretation of nCr, suggesting that these properties ensure the result is always an integer.
  • Another participant echoes the earlier question about the positivity of nCr, reinforcing the discussion on binomial coefficients and their integer nature.
Participants generally agree on the simplification method for 12 C 2, arriving at the same numerical result. However, there is a broader discussion on the properties of binomial coefficients that raises questions, indicating some level of uncertainty and exploration rather than consensus.
The discussion includes assumptions about the properties of factorials and binomial coefficients, but these are not fully resolved or proven within the thread.
This discussion may be useful for individuals interested in combinatorics, particularly those looking to understand simplification techniques and the foundational properties of binomial coefficients.
qwexor
Ok just a basic question. We are given 12 C 2 to evaluate. Which equals
12! / (10!2!)
Is there an easier way to simplify it. We are asked to do it without a calculator.
Thanks.
Compute it. Write it all out. Lots of stuff to cancel out.
You'll end up with 12*11/2 = 6*11 = 66
Cancel everything you can with the larger factorial in the denominator.
12!/10!= 12*11 so 12!/(10!)(2!)= 12*11/2= 6*11= 66.
This is something of an elementary question, but why is it always true that nCr where n>r would always yield a positive integer?
That's a good question. The identity (n+1)Cr=nCr+nC(r-1), valid if n>=1 and 1<=r<=n, is easy enough to prove using nCr=n!/((n-r)! r!). Also, nC0=nCn=1 for all n>=0. These facts embody the construction of Pascal's triangle and let you prove by induction (on n) that nCr is always an integer since it's either 1 or it's the sum of two integers.
You can also think of the combinatorial definition of nCr, the number of r-subsets of an n-set. This is definitely an integer. Of course then you'd have to prove that the factorial expression for nCr is correct...
The nCr are binomial coefficients with the property that n+1Cr = nCr-1 + nCr (think of Pascal's Triangle) with nCn = 1 = nC0. Since 0C0 = 1 it follows that all nCr are integers.
Shmoe beat me to it! :-)
  • · Replies 25 ·
