Can I simulate molecular structures without being a chemist?
The discussion revolves around the possibility of binding two positively charged molecules using oscillating electrons. Participants explore the theoretical aspects of molecular bonding, electron behavior, and potential simulation software for such scenarios.
  • One participant questions whether two positively charged molecules can be bound by electrons oscillating between them, suggesting a specific configuration of electrons.
  • Another participant refers to the concept of electrides and solvated electrons as potentially relevant, noting their instability under standard conditions.
  • A different participant clarifies that while binding two positively charged species is theoretically possible, the behavior of electrons does not align with the proposed oscillation model.
  • Another response emphasizes the need to consider charge neutrality in bonding scenarios and explains the quantum nature of electron positions, which are described by probability density functions.
  • One participant reiterates the original question, indicating a misunderstanding of the electron behavior in bonding and suggesting that electrons occupy molecular orbitals rather than bouncing as described.
Participants express differing views on the feasibility of the proposed electron behavior and its implications for molecular bonding. There is no consensus on the validity of the original question or the proposed model.
Participants highlight limitations in understanding electron behavior, particularly regarding their oscillation and bonding roles, which may depend on specific definitions and assumptions about molecular interactions.
edpell
I am not a chemist. I have a molecular structure question.
Is it possible to bind two positively charged molecules together by having two electrons bounce up and down in the space between them?
M1+ e e M2+
imagine the e, electrons oscillating up and down. Either in sync and 180 degree out of phase.
Is there any simulation software that I could use to simulate a situation like this? Thanks.
Ed Pell
Chemistry news on Phys.org
You may want to check out the literature on electrides and solvated electrons, as they're the closest thing I can think of that might be applicable, based on your description. The idea is that the electron serves as an anion to a cation in lieu of a typical counterion. I don't think most of them are stable under standard temperature and pressure, although I believe there are one or two that have been found.
If you can share more about your idea, I might be able to add more to this brief comment.
Are you asking if its possible to have two positively charged species bound together? Or particularly by electrons bouncing up and down?
Hydrogen molecule ion, H2+ is the simplest molecule and is an example of the former. The latter is not really how electrons behave, they don't just jump around a molecule like a classical particle might.
Hey edpell,
This is more an electron structure question.
M1+ e e M2+
This a charge neutral scenario. When stuff is bonded you must offset the all protons and electrons in the molecule to determine the resultant charge - though experimentally it is possible to determine if one of the molecule's constituents has more charge than the other. Here you seem to be suggesting that the 2 e's are not negating the positive charge of the 2 M's but are instead through their synchronicity/phase relationship are forming a bond between the two positively charged M's - remember electrons themselves are repulsive.
Generally electron positions - determined by probability density functions - are well understood, even in molecules i.e. cuprite, methane. The quantum nature of electrons means we can not know exactly where we will find them in the atom/molecule when we look for them let alone what they were doing before we looked i.e. oscillating.
ch@rlatan.
M1+ e e M2+
Ed Pell
You gave a very complicated description of a covalent bond, however electrons will not "bounce" in the way you suggested - they occupy a molecular orbital and their position is uncertain (read more about wavefunctions).
20K
  • · Replies 41 ·
22K
10K
  • · Replies 50 ·
13K
