What is the Role of Diaphragms in Charge Transfer in Chemistry?
  • Thread starter Thread starter asym
    Chemistry
The discussion centers on the role of diaphragms in charge transfer within electrochemical cells, specifically highlighting their function in preventing the mixing of solutions between half-cells while allowing ionic conductivity. It is established that the diaphragm facilitates charge transfer through a mechanism that involves selective ion exchange, where ions that do not react directly are allowed to pass. The concept of using a (double) ion exchanger is introduced as a critical component in designing these systems for optimal performance.
  • Basic understanding of electrochemical cells
  • Knowledge of ionic conductivity principles
  • Familiarity with ion exchange mechanisms
  • Concept of half-cells in electrochemistry
  • Research the properties and types of ion exchange membranes
  • Study the design and function of electrochemical cells
  • Explore the molecular mechanisms of charge transfer in electrochemistry
  • Learn about the applications of (double) ion exchangers in various chemical systems
Chemistry students, electrochemists, and researchers interested in the mechanisms of charge transfer and the design of electrochemical systems.
asym
In basic chemistry courses you will learn that diaphragm prevents mixing of solutions between half-cells while maintaining ionic conductivity. What exactly carries charge through diaphragm if it's neither electrons, nor ions from the solution? What is the molecular mechanism behind that?
Chemistry news on Phys.org
Ions do travel through the membrane. However, you usually design the system in such a way that traveling ions are those that will not react directly.
So it's some kind of (double) ion exchanger?
  • · Replies 32 ·
