Are there any formulae that involve decibels?
In summary: I think I found a link to a more detailed explanation on Wiki, but I can't find it now. :)I seem to remember someone trying 'decilogs' as a possible way out. I think I found a link to a more detailed explanation on Wiki, but I can't find it now. :)
Ralphonsicus
47
Thanks.
Any formula that deals with "loudness" can be put in terms of decibels. The simplest, of course, is that one decibel is one tenth of a bel!
Ralphonsicus, Google and Wikipedia are your friends...learn to use them to find answers to your questions plus references for where to look for more detailed research. I found this in about one minute! Here are two paragraphs from the Wiki page on “decibel”:
“The decibel (dB) is a logarithmic unit that indicates the ratio of a physical quantity (usually power or intensity) relative to a specified or implied reference level. A ratio in decibels is ten times the logarithm to base 10 of the ratio of two power quantities.[1] A decibel is one tenth of a bel, a seldom-used unit.
The decibel is used for a wide variety of measurements in science and engineering, most prominently in acoustics, electronics, and control theory. In electronics, the gains of amplifiers, attenuation of signals, and signal-to-noise ratios are often expressed in decibels. The decibel confers a number of advantages, such as the ability to conveniently represent very large or small numbers, and the ability to carry out multiplication of ratios by simple addition and subtraction.”
http://en.wikipedia.org/wiki/Decibel
Ralphonsicus said:
Thanks.
Please try to give more context and detail in questions like this. You do not say why you are asking the question, you do not specify which areas of science you are asking about, etc.
It makes it a lot easier for folks who want to help you if you post what you know and what research you have done on the question so far, and what *specifically* you are looking for.
Ralphonsicus said:
Thanks.
Beware the huge amount of rubbish that it talked about the dreaded dB.
In my experience, many people tend to struggle with Logarithms until they get familiar with them from extended use - I mean lots of example problems.
Likewise with dB. You will eventually get a feel for them and you find 30dB will automatically mean a Power ratio of 1000 to you, without thinking about it.
You can reduce the risk of going wrong if you always remember that dB is defined as a ratio of POWERS. It so happens that, when you are operating at the same impedance, you can relate Voltage or Current ratios to power ratios but it really is a nonsense just to say that a multiplication of volts implies a 'gain in dB'. A 1:10 transformer will have a (power) gain of less than 0dB, despite producing ten times as many volts and a 'voltage follower' circuit may have a gain of 60dB, although the voltage gain is 1.
Anyone who you hear using the term " Volts dB" is on shifty ground unless they specify a constant impedance. 60dBμV is OK as long as, somewhere, there is a 50Ω specified.
Shame he breaks the first rule at the start. dB is a ratio of powers so he isn't helping by starting off with Voltage ratios. I am not nitpicking here and his approach can lead to serious misconceptions. Too glib and chatty to be safe, imo.
Well power = voltage^2 / resistance , isn't it? So even if dB is actually a rule which applies for power, we can use it for voltage also given the load remains same (which is most of the case).
Is it the same for a transformer or an amplifier? Like I said, it's dangerous.
What are decibels?
Decibels (dB) are a unit of measurement used to express the relative intensity or loudness of a sound or signal. It is a logarithmic scale, meaning that a small change in decibel level represents a large change in actual sound intensity.
How is the decibel scale calculated?
The decibel scale is calculated by taking the logarithm of the ratio between two quantities. In the case of sound, it is the ratio between the sound pressure level (SPL) and a reference level of 0 decibels, which is considered the threshold of human hearing.
Yes, there are several formulae that involve decibels. One of the most common is the formula for sound pressure level (SPL), which is: SPL (dB) = 20 log (p/p0), where p is the sound pressure and p0 is the reference pressure of 20 microPascals.
How are decibels used in acoustics?
Decibels are commonly used in acoustics to measure and describe the loudness of sound. They are also used in the design and evaluation of acoustic systems, such as in the construction of concert halls or noise control in buildings.
Are decibels the same as hertz?
No, decibels and hertz are not the same. Hertz (Hz) is a unit of frequency, while decibels are a unit of sound intensity. They are related, as a change in frequency can result in a change in sound intensity, but they are not interchangeable units.
  • Classical Physics
  • Other Physics Topics
  • Art, Music, History, and Linguistics
