| New Reply |
Does the equilibrium constant have units? |
Share Thread |
| Jan27-12, 09:55 AM | #1 |
According to my teacher in my chemistry lesson, the equilibrium constant has different units depending on how many moles of reactant and product there are. But the idea of a constant which changes it's units depending on the situation seems a bit dodgy to me, especially as it seems to be related to ratios, and I though ratios are meant to be dimensionless.
Also, the units seem to be based on which power the concentration is to, but seeing as that depends on the moles of the reactants, which is a variable in itself, I would have thought it wouldn't change the units, so I think it is dimensionless. I did some research on this, and some websites confirm my idea, some confirm my teacher's. (I'm going with my teacher's viewpoint for the sake of the exam, anyway, but I want to know which is right.) So which is true? Is it dimensionless, or do the units change depending on the situation? (If this would be more appropriate in the homework help section, please move it.) |
| Jan27-12, 10:14 AM | #2 |
| Jan27-12, 10:36 AM | #3 |
Your teacher is NOT right. However your arguments are not valid either. It's a bit obscure, read carefully.
Proper definition of equilibrium constant involves ratio of activities, not concentrations, and activities are dimensionless by definition. Ex.: [tex]K = \frac{a_{{\rm H}^+} a_{{\rm A}^-}}{a_{\rm HA}}[/tex] Activity may be expresed as a product of an activity coefficient and the relative concentration, which is dimensionless as well, because it is calculated as molar concentration divided by standard concentration, which is conventionaly chosen to be [tex]c_0 = 1~{\rm mol/l}[/tex]. Ex.: [tex]a_{{\rm H}^+} = \gamma_{{\rm H}^+}[{\rm H}^+] = \gamma_{{\rm H}^+}c_{{\rm H}^+}/c_0[/tex] In textbook examples we usually simplify calculations by setting activity coefficients to unity, thus equilibrium constant is expressed in relative concentrations [tex]K = \frac{[{\rm H}^+][{\rm A}^-]}{[{\rm HA}]}[/tex] At this step people (even specialists and authors of textbooks) often forget, than concentrations are still relative = dimensionless. This is the contemporary view - you might find different and less consistent approach in historical books. |
| Jan28-12, 01:54 AM | #4 |
So basically neither of us are right? Good to know.
| Jan28-12, 08:30 AM | #5 |
Equilibrium constant, as it is properly defined (through the mass action law), has no units. What asym said is correct. Chemistry teachers deliberately teach the "wrong" definition to avoid talking about activities or fugacities divided by standard pressure (a dimension-less ratio). Even with your teacher's definition, the equilibrium constant does not depend on how many moles of reactant are there. Do not confuse stoichiometric coefficients with number of moles
| Feb8-12, 12:32 AM | #6 |
Since the teacher chooses to express the equilibrium constant in terms of concentration, THE EQUILIBRIUM CONSTANT WILL HAVE UNITS... it doesn't matter if it is used as a dimensionless quantity. If the teacher expresses it in terms of concentration, you must use units for full marks. Teacher is right. |
| Feb8-12, 02:00 AM | #7 |
The teacher is right about a wrong definition, that's what I'm saying, and I think that's what the OP wanted to know.
| Feb8-12, 02:27 AM | #8 |
Recognitions:
| Feb8-12, 03:26 AM | #9 |
| New Reply |
Similar discussions for: Does the equilibrium constant have units?
| Units of Coulomb's Constant | Introductory Physics Homework | 3 | ||
| Units on Plank's constant | General Physics | 1 | ||
| units of solar constant | Introductory Physics Homework | 4 | ||
| What are the units of spring constant K? | Introductory Physics Homework | 2 | ||
| Cosmological Constant in mks units | Cosmology | 6 | ||
