Understanding Simple Lie Groups: Definition and Common Misconceptions
The discussion revolves around the definitions of simple Lie groups, specifically comparing a definition from Naive Lie Theory by John Stillwell, which states that a simple Lie group has no non-trivial normal subgroups, with a definition from Wikipedia that describes a simple Lie group as having no connected normal subgroups. Participants explore the implications of these definitions and their historical context, as well as the classification of the group SU(2).
  • Some participants propose that the Wikipedia definition is more common and useful, while others question the historical context of the definitions and the notion of simplicity in Lie groups.
  • There is confusion regarding the classification of SU(2) as simple, with some asserting it is not simple under either definition due to its normal subgroups being connected.
  • Participants discuss the concept of "almost simple" and suggest that labeling SU(2) as simple may stem from a misunderstanding or sloppiness in terminology.
  • One participant argues that the Wikipedia definition is inadequate, suggesting that closed normal connected subgroups should also be excluded to avoid including 'interesting' normal Lie subgroups.
  • Another viewpoint is presented that a simple Lie group should be defined in terms of its Lie algebra being simple, highlighting the limitations of the naive definition.
Participants express disagreement regarding the definitions of simple Lie groups and the classification of SU(2). There is no consensus on which definition is more appropriate or widely accepted.
Participants note that the definitions may depend on the context and that the historical development of the concept of simplicity in Lie groups is not fully resolved. The discussion highlights the complexity and nuances involved in defining simple Lie groups.
Matterwave
Hello,
I am reading Naive Lie Theory by John Stillwell, and he gives the definition of a simple Lie group as a Lie group which has no non-trivial normal subgroups.
Wikipedia, on the other hand, defines it as a Lie group which has no connected normal subgroups.
I was wondering, which definition is more common in the literature, and which definition did Lie use, etc? There seems to be quite a bit of difference between the two definitions since under the first definition, for example, SU(2) is not simple, [STRIKE]while under the second definition, it is (since it's non-trivial normal subgroups 1 and -1 aren't connected).[/STRIKE]
The first definition is certainly more restrictive, and would eliminate all SU(n) and Sp(n).
EDIT: Wait a second...SU(2) is a connected group so...even under the second definition, it's not simple right? ... So why do I see it labeled as simple all the time? I'm confused.
The Wikipedia definition is the more common (and more useful) one. Some authors make a point of saying "almost simple" to make sure there is no misunderstanding.
I don't think Lie was concerned with such notions as simplicity (but I could be wrong). It probably wasn't until the work of E. Cartan and Killing that simplicity was defined; I would guess it first popped up in the context of the Cartan-Killing classification of complex semisimple Lie algebras. Incidentally, the reason for the utility of the "almost simple" concept for Lie groups is that it's really the appropriate definition to make if you want to port the classification over from the Lie algebra to the Lie group side of things.
What does the connectedness of SU(2) have to do with its simplicity? You're looking for proper connected normal subgroups.
I thought that SU(2) was "simple" because I incorrectly thought that it's 2 normal subgroups weren't connected. But they are, so SU(2) is not simple by either definition of "simple".
I guess it's simply "almost simple"? And then classifying it as simple, like I've seen many people do, is just a slight sloppiness?
I should have read your post more carefully. The wikipedia definition you quoted is no good either: you want to exclude closed normal connected subgroups. This is because you don't want 'interesting' normal Lie subgroups. (Another technical provisio: you don't want your group G to be abelian.)
In some sense, yes. But really it's more of an issue of overloading the word "simple". A simple Lie group isn't a Lie group that's simple as a group. It really ought to be a Lie group that has no 'interesting' Lie groups as quotients. That's one point of view. Another (but essentially equivalent) point of view is that a simple Lie group should be one whose Lie algebra is simple (=is nonabelian and has no nontrivial ideals). In some sense, this is really where the problem with excluding all normal subgroups comes from: the Lie algebra won't detect discrete normal Lie subgroups, in the sense that they correspond to the zero subalgebra, and so the simple Lie algebra <-> simple Lie group correspondence doesn't hold for the naive definition of a "simple Lie group".
ok, thanks for the info. =]
  • · Replies 26 ·
  • · Replies 0 ·
