| New Reply |
A particle decays into two daughter particles.Find velocity pf daughter particles? |
Share Thread | Thread Tools |
| Jan29-12, 12:40 PM | #1 |
A particle of rest mass m moving with speed c/2 decays into two particles of rest mass 2m/5 each.The daughter particles move in the same line as the direction of motion of the original particle.Then what are the velocities of daughter particle? 2. Relevant equations Momentum conservation: p = p1+p2 Energy conservation: (p2c2+m2c4)1/2=(p12c2+m12c4)1/2+(p22c2+m22c4)1/2 3. The attempt at a solution Can i assume that both daughter particle has same momentum(velocity)? otherwise the second equation becomes really complicated.:( |
| Jan29-12, 01:31 PM | #2 |
Try solving the problem in the rest frame of the original particle, and then transform back to the lab frame.
| Jan30-12, 12:39 AM | #3 |
In the frame of original particle, the daughter particles will have equal and opposite momentum.
Then?how to proceed? |
| Jan30-12, 01:04 AM | #4 |
What are the energy and the magnitude of the momentum of each particle?
| Jan30-12, 03:59 AM | #5 |
velocity of the particles in the frame of original particle,[tex]v=\frac{\frac{c%
}{2}+v^{\prime }}{1+\frac{v^{\prime }c}{2c^{2}}}[/tex] magnitude of momentum,[itex]p=\frac{2}{5}\frac{mv}{\sqrt{1-\frac{v^{2}}{c^{2}}}}[/itex] Energy =[tex]\left( p^{2}c^{2}+m^{2}c^{4}\right) ^{1/2}[/tex] am i correct? But things seems much more complicated.
| Jan30-12, 04:25 AM | #6 |
You're kind of going backwards. First, what is the energy of the particle in its rest frame? Then by conservation of energy, what can you say about the energy of the decay products? Then calculate their momenta.
| Jan30-12, 05:03 AM | #7 |
At rest frame,
Energy = mc2 By conservation of energy, [tex]2(p^{2}c^{2}+\frac{4}{25}m^{2}c^{4})^{1/2}=mc^{2}[/tex] [tex]p=\frac{3}{10}mc[/tex] is that right? |
| Jan30-12, 05:10 AM | #8 |
and velocity of the daughter particle in this frame,
[tex]v=\frac{3}{5}c[/tex] |
| Jan30-12, 05:28 AM | #9 |
And on converting it to lab frame,i got,
[tex]v=\frac{c}{7}[/tex] I think now i started to understand. Thanks a lot ![]()
| Jan30-12, 10:51 AM | #10 |
| Jan31-12, 05:19 AM | #11 |
Each new particle has velocity ,±5c/3 . In the lab frame one particle has velocity +11c/13 and other has velocity -c/7. Why aren't they equal? even when both of them have same mass and is produced from same particle? |
| Jan31-12, 05:24 AM | #12 |
If they were equal in the lab frame that would violate conservation of momentum, since the original particle has non-zero momentum...
| Jan31-12, 05:28 AM | #13 |
yes i understood. thanks. :)
| New Reply |
| Thread Tools | |
Similar Threads for: A particle decays into two daughter particles.Find velocity pf daughter particles?
| Kinetic energy of daughter nucleus and alpha particle from alpha decay | Introductory Physics Homework | 1 | ||
| Kinetic Energy of a daughter Particle in Alpha decay. | Advanced Physics Homework | 0 | ||
| There are N point particles in a volume V. Find the mean distance between particles. | Introductory Physics Homework | 1 | ||
| Velocity of daughter nucleus | Advanced Physics Homework | 3 | ||
| Physics of Particles - something that decays to muons | Advanced Physics Homework | 0 | ||
