Specific heat capacity and changing temperature of water
The discussion focuses on calculating the final equilibrium temperature when a 15 kg rock at 250°C is dropped into a 160L bath of water at 41°C. The specific heat capacities are 4000 J/kg°C for water and 2000 J/kg°C for the rock. The principle applied is that the heat gained by the water equals the heat lost by the rock, leading to the equation Q=cmΔT. This allows for the determination of the final temperature of the system.
  • Understanding of specific heat capacity
  • Familiarity with the equation Q=cmΔT
  • Basic knowledge of thermal equilibrium
  • Ability to perform algebraic manipulations
  • Study the concept of thermal equilibrium in detail
  • Learn about specific heat capacity calculations for different materials
  • Explore heat transfer principles in thermodynamics
  • Practice problems involving heat exchange between solids and liquids
Students studying physics or chemistry, particularly those focusing on thermodynamics and heat transfer principles.
rugby123
there is a bath of 160L of water at 41oc (shc 4000). A rock of 15kg is dropped into the bath at 250oc with shc of 2000
What temperature does the water end up at?
Q=cmT
Very sorry but I don't have a clue. Not really on A2 spec
hi rugby123! :wink:
the rock and the water will end up at the same temperature
so use the fact that the heat gained by the water equals the heat lost by the rock …
what do you get? :smile:
