Solve Equation 0 = (cos x)^2 - x^2 or 0 = cos x - x
  • Thread starter Thread starter Eppur si muove
The discussion revolves around solving equations of the form 0 = (cos x)^2 - x^2 and 0 = cos x - x, which are identified as transcendental equations. Participants express uncertainty about finding analytical solutions and explore various approaches to tackle the problem.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the challenges of isolating x using inverse cosine functions and consider the implications of the equations being transcendental. Some suggest graphical methods to find intersection points, while others mention using Taylor series for approximations.
The discussion is ongoing, with participants sharing different methods and questioning the feasibility of finding exact solutions. Some guidance has been offered regarding graphical approaches and series expansions, but no consensus has been reached on a definitive method.
Participants note that analytical solutions for the given equations are rare, and the discussion includes considerations of approximation methods due to the nature of the equations.
Eppur si muove
I came upon an equation similar to 0 = (cos x)^2 - x^2 or even 0 = cos x - x and i don't have a clue how to solve it analytically. I tried taking inverse cosine function on both sides but that still doesn't isolate the x. How would you do it?
The first eq.includes the second one as it can easily be factorized:
[tex]\cos^{2}x-x^{2}=(\cos x+x)(\cos x-x)=0[/tex]
The two equations obtained as called by the mathematicians "transcendental equations".They are exactly analytically solvable (sorry fo pushing English grammar :-p ) very rarely,and the 2 written above NEVER.
It this case an approximative method is useful and the first one that comes to my mind is the graphic one.Simply plot [itex]\cos x[/itex],[itex]x[/itex] & [itex]-x[/itex] and the solutions to your problem will be the intersection points.
Daniel.
I've approached my original problem differently and now have an equation of the type Acos x = Bcos((pi)x/C)). I have a problem expanding it however. Is there an identity that expands cos(ax) into cos x + f(x) or (cos x)f(x) ?
you could use a taylor series to get a good approximation of cos x and then you should be able to solve for x from that.
that is probably more work than you need to do however, but it is a good place to go if you are desperate.
so there is no ther way? Is it not possible to find an EXACT solution?
See the third sentence of the first reply.
  • · Replies 29 ·
