| New Reply |
Correct this improper definition of a limit |
Share Thread |
| Feb3-12, 06:49 AM | #1 |
Eddy wrote on his midterm exam that the definition of the limit is the following: The sequence {an} converges to the real number L if there exists an N ∈ Natural numbers so that for every [itex]\epsilon[/itex] > 0 we have |an − L| < [itex]\epsilon[/itex] for all n > N. Show Eddy why he is wrong by demonstrating that if this were the definition of the limit then it would not be true that lim n→∞ 1/n = 0. (Hint: What does it mean if |a − b| < [itex]\epsilon[/itex] for every [itex]\epsilon[/itex] > 0?) 2. Relevant equations |a-b| <ε means that ||a|-|b|| < ε from the reverse triangle inequality 3. The attempt at a solution I know it has to do with the fact that the actual definition of a limit has "for every ε > 0, there exists an N [itex]\in[/itex] Natural numbers S.T. ...." so, Eddy reversed that part of the definition. I just haven't been able to quite see the difference of the two. A little push in the right direction would be greatly appreciated. I like figuring these out on my own, so no full on answers, please. |
| Feb3-12, 08:25 AM | #2 |
Mentor
So there exists a certain N.
Let [itex]\varepsilon = |1/N|[/tex] and try to prove that 1/n does not converge to 0 with this definition. |
| Feb3-12, 08:51 AM | #3 |
I'm not quite sure I follow. I ended up answering it this way: Eddy's definition implies there is a single natural number, N, such that for all n>N |1/n|< every epsilon greater than zero. Which is not true. For every epsilon you give me, I can find an N such that 1/n is less than that epsilon for all n>N, but if you pick a newer, smaller epsilon, my N has to be larger, and since the natural numbers are unbounded, we can do this forever. But, it's a different N for each new epsilon, not one single N like eddy implied. Does that make sense?
| Feb3-12, 11:58 AM | #4 |
That's right.
| New Reply |
Similar discussions for: Correct this improper definition of a limit
| Show limit of improper integral is 0 | Calculus & Beyond Homework | 3 | ||
| am i correct with bolzano Weierstrass lim inf/sup definition.. | Calculus & Beyond Homework | 0 | ||
| Correct definition of planetary precession | General Astronomy | 0 | ||
| Prove limit of improper Integral is 1 | Calculus & Beyond Homework | 3 | ||
| Correct Definition? | General Physics | 30 | ||
