Calculate the value of kb for this base
  • Thread starter Thread starter nysoprano
    Base Value
The discussion focuses on calculating the base dissociation constant (Kb) for a 0.200 M solution of a weak base with a pH of 10.40. To determine Kb, one must use the equilibrium expression for weak bases, considering that they do not fully dissociate in hydroxide ions. The equilibrium concentration of hydroxide ions can be derived from the pH value, which is essential for solving the Kb equation.
  • Understanding of weak base dissociation and equilibrium concepts
  • Knowledge of pH and pOH calculations
  • Familiarity with the Kb expression for weak bases
  • Basic algebra for solving equilibrium equations
  • Learn how to calculate pOH from pH values
  • Study the equilibrium constant expressions for weak bases
  • Explore examples of Kb calculations for various weak bases
  • Review the concept of hydrolysis in weak base solutions
Chemistry students, educators, and anyone involved in analytical chemistry or studying acid-base equilibria will benefit from this discussion.
nysoprano
pH help??
This is the question i need help in:
A 0.200 M solution of a weak base in water has a pH=10.40. Calculate the value of kb for this base.
I know the answer but i need help on how to get that answer. Thanks
Chemistry news on Phys.org
If its a weak base then it doesn't diassociates completely in OH ions, so you need to use the equilibrium solution.
This may help: see post #5 here.
  • · Replies 21 ·
