Simplifying Equations with Polynomial denominators/numerators
The discussion revolves around simplifying equations with polynomial denominators and numerators, specifically involving expressions with terms like x^n and their factorizations.
  • Participants discuss various attempts to factor expressions, including substituting variables to simplify the equations. Questions arise about the validity of these substitutions and the implications for the original problem.
Some participants have provided guidance on substitutions and factorizations, while others express uncertainty about the correctness of their approaches. Multiple interpretations of the problem are being explored, and there is no explicit consensus on the best method to proceed.
There are concerns about potential point deductions for using substitutions, and participants are considering how to approach the problem without them. The original equations are complex, and the clarity of the problem setup is questioned.
darshanpatel
I uploaded a picture of the question because I didn't want to confuse people from the way it looks because it is pretty long.
http://tinypic.com/r/2itpm39/5
-None-
I went from the original equation and took an 'x' out of the first numerator and then got the reciprocal of the x^n and multiplied that through
1. Original Equation
2. (((x^n)-8)/((x^2n)+(2x^n)+1)) x ((x^2n)-(4x^n)-5)/(x^n)
I don't know what I can factor out from this point..
Please help and thanks
-None-
x2n = (xn)2
That in itself may help you. If not, then let u = xn and substitute that.
Do you mean x^2n= (x^2)^n
Also as an example, if I took x^n-8 and did that, would it be:
((x)^3n)-(2)^3
and i don't know where to go from there
and for this one:
(x^2n)-(4x^n)-5
((x^2)^n)-((4x)^n)-5
what would i do next?
While that's true, SammyS was right to say
x2n = (xn)2
So if you were to make the substitution u = xn,
xn - 8 would become u - 8.
darshanpatel said:
and for this one:
(x^2n)-(4x^n)-5
With the substitution, it would be
x2n - 4xn - 5
= (xn)2 - 4xn - 5
= u2 - 4u - 5
Now do the same kind of substitution in the first denominator. Doesn't that expression look familiar now? And can't you do something with u2 - 4u - 5?
I substituted all the x^n with y's and ended up with:
(((x^n)-5)((x^n)-2)((x^2n)+(2x^n)+4))/(x^n)((x^n)+1)
Is that all it can get factored and simplified?
Also, I think i will lose points by substituting, what is the way without it?
((xn ) - 2) ((x2n ) + (2xn ) + 4) = x3n - 8 ≠ xn - 8
I redid it and got: (((x^n)-8)((x^n)-5))/(x^n)((x^n)+1)
Is that correct?
Sorry, I didn't get what you are trying to say
Is that correct?
If you mean
[tex]\frac{(x^n-8)(x^n-5)}{x^n(x^n+1)}[/tex]
... then yes, looks right.
Substituting isn't necessary, but makes things look simpler.
For example, if you were asked to factorize
[tex]x^2+4ax+4a^2[/tex]
then it isn't very clear what needs to be done, but if you let 2a=b then you have
[tex]x^2+2bx+b^2[/tex] and this is clearly a perfect square, so you can factorize it as so:
[tex](x+b)^2[/tex] and then you can substitute back in at the end to obtain
[tex](x+2a)^2[/tex]
  • · Replies 16 ·
  • · Replies 35 ·
  • · Replies 22 ·
