Two bodies are falling with negligible air resistance
In the discussion regarding the motion of two bodies falling with negligible air resistance, it is established that when one body is given an additional horizontal acceleration, it will strike the ground at the same time as the other body. The vertical components of velocity and acceleration remain unchanged, confirming that the only effect of the horizontal acceleration is on the horizontal motion. The correct conclusion is that the second body follows a parabolic path, not a hyperbolic one, and the only true statement is that both bodies strike the plane simultaneously.
  • Understanding of Newton's laws of motion
  • Knowledge of vector components in physics
  • Familiarity with projectile motion concepts
  • Basic calculus for analyzing motion equations
  • Study the principles of projectile motion in physics
  • Learn about vector decomposition and its applications
  • Explore the effects of air resistance on falling bodies
  • Investigate the mathematical modeling of parabolic trajectories
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of falling objects and vector analysis.
Aerospace
Two bodies are falling with negligible air resistance, side by side, above a horizontal plane.
If one of the bodies is given an additional horizontal acceleration during its descent, it
1. has the vertical component of its velocity altered
2. strikes the plane at the same time as the other body
3. follows a hyperbolic path
4. has the vertical components of its acceleration altered
5. follows a straight line path along the resultant acceleration vector
I was thinking it might be either 1 or 4...but I'm not very sure...I don't think that the acceleration would be altered because it's constant? But can someone help me confirm that or help me understand the solution? The homework is due today.
Thanks.
Applying a horizontal force to the object will alter it's acceleration in the horizontal plane, but not in the vertical one. It should still strike the ground at the same time, just farther away from the other object.
That's the whole point of using "components" of vectors.
Adding a horizontal acceleration affects only the horizontal components of acceleration, velocity and position.
1. is false- only the horizontal component is altered.
2. is true since the vertical component of the position function is not changed.
3. is false: it follows a parabolic path
4. is false. Again, only the vertical component is altered.
5. is false- see 3 above.
2. is the only true statement.
  • · Replies 47 ·
