How to determine zinc in a plant.
  • Thread starter Thread starter kenshi64
    Plant Zinc
The discussion revolves around methods for determining the concentration of zinc in plants, specifically focusing on extraction techniques and analytical methods such as Atomic Absorption Spectroscopy (AAS) and colorimetry. Participants explore the challenges of extracting zinc from plant tissues and the need for complexing agents to facilitate measurement.
  • Homework-related
  • One participant questions the feasibility of using AAS without a calibration curve, suggesting a lack of understanding of the method.
  • Another participant expresses confusion about whether AAS provides direct concentration readings, indicating a misunderstanding of the technique.
  • A participant seeks guidance on the methodology for extracting zinc from plant material, noting incomplete information in existing literature.
  • Suggestions are made to conduct literature research for methodologies and references related to zinc extraction from plants and soil.
  • One participant mentions the need for a complexing agent to determine zinc concentration using colorimetry, as zinc is colorless.
  • A later reply indicates that separating zinc from other elements is necessary for accurate colorimetric analysis, highlighting the complexity of the process.
  • Another participant shares a potential complexing agent, zincon, but expresses concerns about its cost and availability.
  • One participant indicates a preference for AAS over colorimetry due to difficulties in finding suitable complexing agents.
Participants express varying levels of understanding and capability regarding the extraction and analysis of zinc, with some agreeing on the challenges posed by the methods discussed. However, no consensus is reached on the best approach or the specifics of the methodology.
Participants highlight limitations in available literature and the complexity of the extraction and analysis processes, noting that methods may require significant effort and specific conditions that are not fully detailed in the references provided.
Students and researchers interested in plant analysis, particularly those working with metal extraction and measurement techniques in chemistry and environmental science.
kenshi64
Which would you prefer? I'm calculating the amount of zinc absorbed by a particular plant (yes, in theory it does accumulate zinc- B.Juncea).
Chemistry news on Phys.org
Question doesn't make sense. How are you going to use AAS without a calibration curve?
Woops! ignore my ignorance, I was just told that, well doesn't the AAS give you the concentration directly? Gosh, just pointless maches *argh*
CHANGE: AAS or COLORIMETER
How would you extract zinc from a plant?
Hi!
So I basically need to find out how I'm supposed to extract zinc from a plant and its methodology and chemicals required. How do I do this? I found one article that is rather incomplete, it just says zinc was extracted using 0.1N HCl and not whether the plant's powder was treated with it or the entire plant was treated with it.
Here's a "www.sc.chula.ac.th/nrc-ehwm-fs/research/journal/5.pdf" .
Your reference has some clues (there are citations about preparing samples of soil). Start with these and work through references that will be found in those initial citations. Literature research always gives clues about how to proceed and achieve reproducibility in any analysis.
Another reference (found in many science libraries) would be the A.O.A.C Methods which are matrix specific analyses for foodstuffs, crops, soil, and other agricultural i.e. They can be somewhat difficult to navigate but official methods can be found for plant and soil analysis.
Official Methods of Analysis of AOAC INTERNATIONAL,18th Edition
Wiki AOAC International...
Urgent: Some complexing agents for zinc.
Hi, I am to extract Zinc from plant tissue, with 0.1N HCl. But since its colorless I cannot determine the concentration(using the colorimeter) of zinc without adding a chemical that forms a complex with zinc and has a color.
Have you followed MrSid's hints?
Sorry, that's beyond me! :O I'm just a 17 year old guy! Please sympathize with me, this is tough enough with so much chemistry that's waay about my level!
I suppose then that you don't have an atomic absorption spectrometer at hand but only a colorimeter.
Before determining the concentration of Zn usin colorimetry, you will have to separate it from other elements. That's all rather complicated.
I found an old article describing how this can be done and which in principle can be done in the lab of a school. However, it is in German and the method requires a lot of work.
http://onlinelibrary.wiley.com/doi/10.1002/jpln.19560740105/pdf
Talk about luck haha! My mum's been teaching german for 15 years, however, A complexing agent I did come across was zincon, which was holy costly! Yes, so sorry for the late up date. But I'm going with AAS since I can't find a complexing agent other than zincon for zinc.
  • · Replies 23 ·
61K
