Is our Solar System a large Atom?
The discussion explores the analogy between the solar system and atomic structure, questioning whether the solar system can be viewed as a large atom. Participants examine similarities and differences between these two systems, touching on concepts from physics, cosmology, and theoretical frameworks.
  • Some participants suggest that the solar system and atoms share similarities in structure, proposing that both consist of mass and can be divided into smaller components.
  • Others argue that the rules governing the macroscopic realm (solar system) differ significantly from those of the quantum realm (atoms), asserting that the analogy is flawed.
  • One participant notes that while nature exhibits self-similarity at different scales, the solar system does not resemble an atom in any meaningful way, emphasizing the probabilistic nature of atomic behavior.
  • A question is raised about whether forces like gravity in the solar system could be analogous to the strong force at atomic scales, suggesting that forces may behave differently when condensed.
  • Another participant references a paper proposing a Cantorian spacetime, which advocates for self-similarity across scales, from atomic to astrophysical.
  • Several participants reflect on the historical depiction of atoms resembling solar systems, noting that such models have evolved as scientific understanding has progressed.
  • One participant introduces the idea of dimensions and the possibility of vast universes existing within them, likening this to a "verse" in a larger context.
  • Another participant describes the modern understanding of electron behavior as clouds of probability rather than fixed orbits, contrasting this with the deterministic orbits of planets in the solar system.
Participants express a range of views, with some supporting the analogy between the solar system and atomic structure, while others firmly reject it, citing fundamental differences in governing principles. The discussion remains unresolved, with competing perspectives on the validity of the analogy.
Participants highlight limitations in understanding the forces and behaviors at different scales, noting that assumptions about similarity may not hold under scrutiny. The discussion also reflects on the evolution of scientific models and the challenges of accurately representing complex systems.
Abstruce
What do we know about the atom? All we know is that it has mass and that mass is energy. We know that when you smash an atom you get smaller parts.
Ok let's forget the silly names we give everything and let's call mass well let's call mass mass.
We know that our solar system is made up of mass and if you smash it you will get smaller parts. We also know that our Solar System is part of a system let's call it a Galaxy or a Molecule what ever you like.
Lets say that an atom is part of a galaxy well it is isn't it. Has anyone calculated how many atoms are in a grain of sand vs. how many stars are in a Galaxy.
Now with all these similarities aside let us remember that Nature tends to repeat it's self.
Now if you were nature and you wanted to evolve different dimensions then would it not be the easiest to make one fit into the other and so on.
First it is Big Bang then it is String Theory then Membrane Theory.
It sounds like cell division to me.
But then again what do I know.
Astronomy news on Phys.org
The macroscopic realm operates according to a decidedly different set of rules than the quantum realm. The short answer is 'no' for more reasons than I care to count.
It is true that much of what we see in nature is self-similar on multiple scales (like fractals), but the solar system is not like an atom in any meaningful way. For instance, electrons aren't little balls uniformly circling the nucleus of an atom. They are bundles of energy that have the potential to exist in a range of locations about the nucleus, and by absorbing or emitting photons they can exist at higher or lower potentials (highly over-simplified explanation!). The laws of nature at the quantum level are a bit disconcerting - with existence expressed as functions of potentials and probability instead of certainty.
If the strong force was in a system the size of the Solar System would it be similar to gravity?
What I am getting at is things seem to get stronger when condensed.
All Gods and Creation Theories are Man Made.
John Quest 2004
This paper
http://arxiv.org/abs/astro-ph/0308370
seems quite suspicious to me, but advocates for the idea that we live in a Cantorian spacetime, self-similar; in the paper they give a law that is appliable to all scales, from atomic to astrophysical scales
just a mechanic
im just a golf course mechanic but for years I have thought back to the days of physics class in high school and remembering the picture of an atom with its satellites circling around it. It struck me how similar our solar system and a atom look alike. I've read in string theory
that dimensions could be up to 10 to the power of 10 or something like that. Inside those dimensions could be more vast universes like ours its just a "verse" like songs or a bible which a has verses and all in conjunction complete itself. so we could be a spec in a molecule in a brick of gods house. And he wouldn't even know it. Theoretically speaking.
just a mechanic no degrees
The picture of the atom with electrons orbiting around the nucleus is essentially the Bohr model of the atom. The modern view is a lot fuzzier, so to speak. The electrons are not whizzing points. They are instead clouds of probability. The shapes of these clouds varies with the different orbitals.
with our 3 dimensional eyes this is what we see. "clouds of probability" what if we could see beyond the 3rd di, would we see more?
That's not a coincidence.
It is often the case that new science is phrased in terms of old science that bears a superficial resemblance, but the similarities usually fade with time. The original models of the atom resembled the solar system because the solar system was something we understood and had already described. The pictures diverged the more we learned about its actual structure and the behavior of the particles within it.
The electron orbits about the nucleus of the atom in an manner that allows us to make, at best, an educated guess as to it's location at any given moment. Think of a ninja with nun-chucks. Now let's substitute the nun-chucks with a swinging tether ball, a ball attached to a string, in the zero gravity environment of space so they won't have the ground or anything else to interfere with the ball. (The ninja being the nucleus and the ball being the electron.) They could swing the ball around them in any direction they wanted. Now as an observer with no way of communicating with them, you could only take a guess as to the exact placement of the ball at any given moment.
Now the planets orbit the sun in our solar system right, does that make them similar? Well, the planets orbit the sun at a determinable rate, in a set direction and in line with the sun's equator. The Mayan's were able to calculate almost the exact location of all the planets over 2000 years ago for any given time, were they lucky? No, with so many determinable factors, it's pretty much a concrete system though the math is a bit more than basic.
