Working of Pulse Input Speed Indicator
The pulse input speed indicator operates by measuring the frequency of received pulses, which correlates directly to speed. In analog systems, the average voltage is filtered from the pulse frequency, while digital systems simply count pulses over a defined "gating time" of one second. Calibration involves comparing the speed reading with a reliable reference, such as GPS, and adjusting either the pulse width for analog systems or the gating time for digital systems to ensure accuracy.
  • Understanding of pulse signal processing
  • Familiarity with analog and digital measurement systems
  • Knowledge of calibration techniques
  • Basic concepts of speed measurement
  • Research pulse signal filtering techniques for analog systems
  • Learn about digital pulse counting methods and their applications
  • Study calibration methods using GPS for speed measurement
  • Explore the differences between analog and digital speed indicators
Engineers, technicians, and hobbyists interested in speed measurement systems, particularly those working with pulse input indicators in automotive or industrial applications.
Etude
Hi!
Can anyone please tell me how a pulse input speed indicator works and how one can be calibrated? :smile:
Thanx a lot!
These can be analog or digital.
You need to know how many pulses are being received each second because this is related to the speed you need to know.
So, if these pulses are a constant width, then the average voltage because of them will depend on how many of them are received each second. So, you can just filter them to get a steady voltage and then apply the output to a meter.
The reading will depend on the number of pulses being received each second.
This is the analog method.
Digital is even easier. You just count the pulses for one second and the reading is the number of pulses per second. In this case, 1 second is called the "gating time".
Calibration depends on the actual application. If it was speed of a car, you could use a GPS as a reference speed and compare it with the actual reading being obtained.
You could then adjust the pulse width in the analog system or the gating time for the digital system until the readin was correct.
Hey! Thanx a lot! Explained it nice and short - just what I was searching for. :smile:
  • · Replies 21 ·
