Is the assertion true and the reason false?
The discussion revolves around the validity of specific assertions and their accompanying reasons related to boiling water and the role of catalysts in chemical reactions. It examines whether the reasons provided correctly explain the assertions, focusing on concepts in chemistry and thermodynamics.
  • One participant asserts that decreasing atmospheric pressure on boiling water does not cause it to stop boiling, but rather increases boiling, suggesting a misunderstanding of the relationship between pressure and boiling point.
  • Another participant states that catalysts speed up reactions by lowering activation energy, and this process is not related to temperature changes, challenging the assertion that catalysts can slow down reactions.
  • Some participants express confusion regarding the definitions and relationships between pressure, boiling, and the role of catalysts, indicating a need for clarification.
Participants generally disagree on the assertions and reasons provided, with multiple competing views on the effects of pressure on boiling and the function of catalysts in reactions.
Participants have not reached a consensus on the correctness of the assertions or the reasons, and there are unresolved definitions and relationships regarding boiling points and catalyst behavior.
apchemstudent
Catalysts
I have to state if the "assertion" is true or false and as well the "Reason" if it is true or false. However, i also have to note if the reason is the correct explanation of the "assertion"
The "assertion":
#1.
Decreasing the atmospheric pressure on a pot of boiling water causes it to stop boiling.
The "reason":
Because changes in pressure are directly related to the boiling point of water.
Is the reason a correct explanation of the "assertion"?
#2.
The "assertion":
Catalysts speed up or slow down a reaction.
The "reason":
Because they change the temperature of the reaction.
Is the "assertion" true and the "reason" false?
Chemistry news on Phys.org
i would say both are false,
by definition, a Catalysts speeds up a reaction, it doesn't slow it down.
and the way a Catalysts speeds it up isn't by changing the temperature.
If you decrease pressure liquid water turns to vapor. So it will NOT stop boiling, it will increase boiling.
Catalyst speeds up reaction by lowering the activation energy. Has nothing to do with temp.
I think i understand the boiling point thing now... thanks!
68K
