Relativity: what's wrong with this logic?
  • Context: Graduate
  • Thread starter Thread starter dEdt
    Logic Relativity
The discussion revolves around the invariance of physical laws under various transformations, specifically addressing whether the invariance with respect to spatial and temporal shifts implies invariance under changes in inertial reference frames. Participants explore the implications of these transformations in the context of relativity and provide counterexamples to challenge the initial logic presented.
  • One participant suggests that if physical laws are invariant under spatial and temporal shifts, they should also be invariant under changes in inertial reference frames, questioning the validity of this logic.
  • Another participant provides a counterexample involving two particles, arguing that the law governing their motion is not invariant under Galilean or Lorentz transformations, despite being form-invariant under translations.
  • It is proposed that there may exist other coordinate-transformation laws that could preserve certain physical laws, similar to how Maxwell's equations relate to Lorentz transformations.
  • A participant challenges the initial claim by stating that changing velocity does not equate to alternating between spatial and temporal transformations, emphasizing that these transformations are independent.
  • Further clarification is made regarding local versus global invariance, with a participant asserting that local invariance is necessary and that global invariance leads to non-relativistic implications.
  • Another participant reiterates that the logic presented in the initial post cannot be correct, as it leads to contradictions when applied to the counterexample provided.
Participants express disagreement regarding the implications of invariance under transformations. There is no consensus on whether the initial logic holds, as some participants provide counterexamples and challenge the reasoning presented.
Participants note the distinction between local and global invariance, highlighting that the initial argument may overlook important aspects of how transformations interact with physical laws. The discussion also touches on the implications of these transformations for theories of gravity and motion.
dEdt
Okay, suppose we know that the laws of physics are invariant with respect to a shift in position, and invariant wrt a shift in time (ie the transformations [itex]\mathbf{r}\ \rightarrow\ \mathbf{r}+\delta\mathbf{r}\ \mathrm{and}\ t\ \rightarrow\ t+\delta t[/itex] preserve the laws of physics). Then wouldn't that imply that the laws are *also* invariant wrt a change in inertial reference frame because a change in velocity amounts to continuously alternating between the transformation [itex]\mathbf{r}\ \rightarrow\ \mathbf{r}+\delta\mathbf{r}\ \mathrm{and}\ t\ \rightarrow\ t+\delta t[/itex]? Or is there something wrong with this logic?
Incidentally, I posted this in another site, and someone replied that the logic is fine. But I'm skeptical: I've always viewed the principle of relativity as an experimental fact which is not deducible from other, simpler symmetries.
As a counterexample, take a theory involving two particles at positions [itex]\mathbf{r}_1[/itex] and [itex]\mathbf{r}_2[/itex]. This theory has one law of physics, which is that [itex]d\mathbf{r}_1/dt=-d\mathbf{r}_2/dt=k(\mathbf{r}_1-\mathbf{r}_2)[/itex]. This predicts that the particles scoot directly away from each other at an exponentially increasing speed. The theory is clearly not invariant with respect to Galilean relativity or Lorentz transformations. For example, in a frame that happens to be co-moving with particle 1 at a certain time, particle 1 disobeys the law of motion. But the law of motion is form-invariant with respect to translation in time and space.
Perhaps there exists another coordinate-transformation law which preserves your law of physics.
One could have said something similar about Maxwell's equations: they are symmetric wrt temporal and spatial translations, but are not invariant wrt Galilean transformations. But they contain within themselves the seeds of the Lorentz transformations, which do preserve Maxwell's equations.
No, it doesn't. You can translate in space and time without changing velocity, and you can change velocity without translating in space and time. They are independent transformations.
For example, the Lorentz transformation:
[tex]x' = \gamma \left( x - vt \right)[/tex]
[tex]t' = \gamma \left( t - vx \right)[/tex]
boosts the velocity but does not translate in either space or time. And of course a translation like
[tex]x' = x + X_{0}[/tex]
[tex]t' = t + T_{0}[/tex]
translates in space and time but doesn't change velocity.
The laws of physics need to be locally invariant under translation. What you've described is global invariance. Local invariance is expressed by
[tex] x^\mu \rightarrow x^{\mu '}=x^\mu + \epsilon^\mu(x^\mu)[/tex]
which is saying that the translations depend on position. Global invariance entails action-at-a-distance which is not relativistic.
Interestingly, the translation group is associated with energy and momentum, which are the sources of gravity, and it's possible to make gravity appear in the same way as the Lorentz force, by demanding local translation invariance.
You're missing the point. The logic in your #1 can't be correct, because if it were correct, it would apply to this theory, but the contradiction it leads to when applied to this theory is false.
  • · Replies 22 ·
  • · Replies 146 ·
12K
  • · Replies 0 ·
